polishing a MAF
Old Oct 22, 2008 | 10:11 AM
DARK CHILD's Avatar
DARK CHILD
Default polishing a MAF
CAN I HAVE SOME INSTRUCTION ON HOW TO POLISH MY STOCK MAF AFTER THE SCREENS HAVE BEEN REMOVED? 99" COUPE
THANKS IN ADVANCE FOR ANY INFO.
Old Oct 22, 2008 | 10:29 AM
lucky131969's Avatar
lucky131969
Don't do it....leave it alone..
Old Oct 22, 2008 | 10:38 AM
DARK CHILD's Avatar
DARK CHILD
Ok! What about the screen removal?
Old Oct 22, 2008 | 10:39 AM
lucky131969
See post #2.....
Old Oct 22, 2008 | 10:43 AM
DARK CHILD's Avatar
DARK CHILD
Ok ok i got you. Thanks
and iam gone!
Old Oct 22, 2008 | 11:18 PM
mellowyellow01vert's Avatar
mellowyellow01vert
and iam gone!
I have a CAI, I removed the screen in my MAF, smooth coupler, Bullits Exhaust, stock engine and tune with over 152K miles, and just recently pulled 305rwhp and 312tq. Not bad for a "Road Queen".
JB.
Old Oct 22, 2008 | 11:56 PM
fst85vtt's Avatar
fst85vtt
lmao @ Lucky
Old Oct 23, 2008 | 01:46 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There nothing wrong with removing screnes from the MAF and or doing stuff to it "IF" your going to have the engine TUNED! If you screw with the MAF and dont tune the PCM/MAF Calibrations, your part throttle performance and fuel economey will suffer badly. Remember, you really dont use the MAF the 10% your at WOT. You use your MAF 90% of the time when you NOT at WOT.
lucky131969 advice is right on!
BC
Old Oct 23, 2008 | 01:51 AM
garye904's Avatar
garye904
Default Maf
What about cleaning? Purchased the MAF cleaner not sure how to use, remove the MAF and spray to clean, or spray into the MAF while engine if running?
Old Oct 23, 2008 | 04:27 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Gary
Remove the entire air box assembly and seperate the air filter and air filter cover from the air filter assy. Once you do that you will see the MAF/Screen. Use the cleaner and spray it through the screen. Flush the dirt off the small wires behind the screen. It wont take too much. A couple of good sprays. Then let it evaporate. While you have it apart, clean the TB and Throttle Blade.
Reassemble and that should be that,
BC
Old Oct 23, 2008 | 02:22 PM
lucky131969
JB.
Which is about right for a stock motor....with or without the descreened MAF.
To polishing a MAF
