Comp Mode
Old Oct 23, 2008 | 09:21 PM
pekrul01's Avatar
pekrul01
2nd Gear
Default Comp Mode
I writing this thread for some advise to see if anyone has had this problem. I have a 2K coupe. When i bought the car a year ago the comp mode worked fine when engaged. After using it several times it stopped working. It still shows on the dash that its engaged but the traction control and ABS stop me from spinning the tires. If anyone has had this problem and know the fix or can reccomend what to check i would greatly appreciate it. Thanks
Old Oct 23, 2008 | 11:47 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The first thing that you need to do is read and post the DTCs if any are present. If there there, clear them and test the COMP MODE. See if it works better . If not, see if the DTCs came back
Bill
