For what its worth, I ran my vettes battery low, and when i entered the car to start it i shurt the door and the 2 bottom lights on the DIC didnt light. It was related to the battery voltage.
The lamp's filament is partially contacting and breaking contact... the usual for a failing lamp. Just imagine a small spring that is bouncing on the lead. When it connects, it works. But due to something called "Electron Travel", the filament is failing. Most of the time, they fail once and are done. Contact member "Tstar" as he has a source of supply for the lamps.
Thanks!
I imagined, like most things, it just won't fix itself...
The backlights on my 02 never turn off and eventually runs the battery down. I've been told the IPC will have to be taken to GM for an exchange unit. Not looking forward to that. I was thinking about pulling all related bulbs just to see if that eliminated the load.
dont ask me, thats just what happened when the battery went dead on me. there isnt like regular filiment bulbs being here.. they are led's on a circuit board so i assume it was something allong the lines of the intrument cluster was struggling for power to power all its functions '
Can a single bulb be replaced and what is the level of effort to replace these bulbs? I'd hate to think that i need to replace an instrument cluster to repair the backlighting in two buttons.
The DIC Controller is a self-contained item. Contact forum member Tstar for a source of supply for the lamps as they aren't easy to find or order a DIC controller from Gene Culley. You have to remove the IP Cluster to get to the DIC controller which is screwed onto the cluster from the rear of it. Takes about 15 minutes to pull the cluster if you lower the steering wheel and the same to put it all together again.
Is it possible that the controller is causing my back lights to stay on all the time?
Its possible via the light sensor. The back lighting for the IP Cluster, HVAC, Radio and etc, is controlled by the BCM. The BCM receives its lighting requirements from two different sources. One source is the small light sensor in the DIC controller which during the daytime runs the brightness of the HVAC and Radio indications. When the lamps are on either via the headlamp switch or the twightlight sentinel, the brightness for all indicators comes from the dimmer.
I suggest that you send a PM to Bill Curlee about this as he can point you to a specific location rather than my in general directions...might save some time.
If anyone only needs a bulb or two I can just send them to you while my spares supply lasts. Consider it an early Ho Ho...
Back to this discussion on light types and backlighting... dgrant3830 (as usual) is dead on in that EVERY stock button bulb in the C5 is an incadescent bulb. The only bulbs that are not filament are the IPC gauge lights (FRONT mounted UV tubes) and the electrochromatic mirror maplights (LED arrays).
For the IPC lighting that stays on constantly, this could be a tough one to track down. It could be an internal IPC issue or a wrong external signal via the courtesy light circuit or headlight switch...
If thats the case then whats in the Climate contol on the buttons and the back light?
