HELP PLEASE!! Electrical problem
Old Oct 24, 2008 | 06:23 PM
roborog's Avatar
roborog
Cruising
Default HELP PLEASE!! Electrical problem
OK, I'm confussed (normal state). I got back from a long run and the passenger door mod decided not to work, no locks or window function. I checked the fuses under the floorboard, pulled them out to check (30,31,33,34), all were good. I know the mod in the door is good because I hit a bump the other day and it decided to work again (for a moment anyway). I am thinking it must be a loose connection between the door mod and the fuse box. Have not yet checked the connection between the door and body panel, if there is one. At any rate, after pulling the fuses to check them I created another problem that was not there before! Now when I get in the car to go somewhere all hell breaks loose. Start car and next thing you know everything goes crazy. Radio & AC die. Door locks & window on drivers side go dead. Gauges read: Temp-260, Oil-zero, volts-works fine, Fuel-zero, ABS/act.handling/check gauges-all ON. After driving for awhile (not long) everything decides to work again, with the exception of the original problem, the passenger door controls. Any thoughts?? HELP!!
Old Oct 24, 2008 | 06:58 PM
dougbfresh's Avatar
dougbfresh
I think where the wires tun out the door is prone to problems (inside the rubber acordian). Bad/loose connections are the issues inside-you can search on it but it's a known problem area.
Old Oct 24, 2008 | 07:05 PM
stormrider's Avatar
stormrider
I know this sounds crazy but try shaking the rubber boot that the wires run through. Also, try disconnecting the battery for a few minutes then reconnecting the battery. I had the same symptoms and it turned out I had tripped a circuit breaker. Last of all, PM Bill Curlee and what ever he tells you to do overrides anyone else's suggestions.
Good luck
Old Oct 24, 2008 | 07:14 PM
mellowyellow01vert's Avatar
mellowyellow01vert
I had a weak battery that caused all kinds of gremlins. You might want to have your battery checked.
JB.
Old Oct 24, 2008 | 07:49 PM
roborog's Avatar
roborog
Cruising
Thanks for the suggestions guys. I will try them out. Do you think the battery disc. might take care of the other probs????
Old Oct 24, 2008 | 08:38 PM
mellowyellow01vert
One thing at a time...
Old Oct 24, 2008 | 08:51 PM
stormrider's Avatar
stormrider
Good advice
Old Oct 24, 2008 | 08:52 PM
roborog's Avatar
roborog
Cruising
Got that right Mellowyellow, one thing at a time. Just went out, removed the boot and stuck my fingers in to play with the connection. Guess what, ALL problems solved, at least for the time being!!!! Will take it for a little run in the morning to see if it holds. If not I would guess that I will have to remove the door panel to get to the connector and make sure it is right.... Thanks again for the info people. Will update the results tomorrow!!!!
Old Oct 25, 2008 | 05:01 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Good luck
Your a NUT! Now,,if my wife would only follow your suggestions!
Old Oct 25, 2008 | 06:49 AM
DAV162's Avatar
DAV162
Bill knows a vette inside and out Follow his suggestions.
Old Oct 25, 2008 | 07:32 PM
roborog's Avatar
roborog
Cruising
OK people, just got back from that little run. The mountains were just to nice today so I really put it through its paces. GUESS WHAT, everything is working just fine. It would appear that fingering the heck out of that stupid connector worked!!!! Look out Bill, next time I might just decide to bug you!!! Thanks again for the help folks.....
Old Oct 26, 2008 | 03:12 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I'll bug you first! It would be a wise move to go ahead and pop out the accordion tube inspect the wires, look for bare wires fix them and drive worry free.
Bill
To HELP PLEASE!! Electrical problem
