Help!!!!!!! Auto to manual trans. Switch
Here's the deal: I have a automatic c5 and I'm thinking about switching to a manual transmission instead of purchasing a new car. Is there any draw backs to doing this type of switch? I have a manual C5 transmission with 35,000 miles on it and my current a4 transmission has 65,000 miles on it. I have a good deal on the install and I'm just wanting to know if this is a good idea or not. I really like my car and I don't want to get rid of it, but I want a manual at the same time. I just am nervous about there being problems, so if anyone has any insight on this issue your comments would be greatly appreciated.
The wife and I scheduled a road trip from Texas to Indianapolis, gave the car to Randy for a couple of days, and drove back with a stick. Right after I got home I had to replace the master cylinder. Since then I've put about 10K miles on it with no problems. We love it.
BTW, you mention you have the transmission. I assume you also have a clutch, pedals, etc. I believe the torque tube is also different between the A4 and M6, but I could be wrong.
You will need:
The shop manuals for your year Vette, it will be needed for all the wiring diagrams and connector information.
Clutch pedal assembly
master and slave cylinders
remote clutch bleeder
clutch and flywheel
shifter, with boot and ring, and close out.
torque tube
transmission wiring harness
3.42 diff, not sure how well the 3.15 or 2.73 will do with a MM6
clutch pedal safety switch
cruise control switch
re-programing on the computer
I got all of my new parts at: www.gmpartshouse.com
You will also need a couple of connectors that will go on the main harness to hook up to the trans harness, but you won't know exactly what you will need until you have it apart and know the part numbers on your wiring harness.
I would also consider re-building the manual trans before installing it. Also, look at rebuilding the torque tube. You do not really know how either were driven before you bought them, they could have a short life left in them.
Is it worth it? I really like my MM6, its a lot different than the A4. You can not tell it use to be a A4. It is mostly plug and play, not a lot of places to cut corners. I can't really say it has a down side, other than if you were to sell it, a buyer may balk at the idea, but there are a lot of buyers out there. But, it was worth it to me because I like to take my Vette to the road race track and the MM6 does not overheat nearly as much as the A4 on the track. I would not do it because your A4 has miles on it. Do it because you want or need a manual.
YMMV,
otherwise its easier to sell yours and buy a Manual c5. I know no one likes that,but for the money youd spend you could spend it fixing the manual one up- LIke cosmetic stuff and whatnot.
However, I would definitely agree that it is a major task and should not be approached lightly. Trading for a manual may be cheaper, and it will definitely take less time. Only do the swap if you really need it or have no other good way to get a manual. Only you can decide if its worth the trouble.
Am I contradicting myself, kind of, it is not for everyone and it is a lot of work. I wanted the experience, so it made sense for me. Most would rather do other mods or just drive it like it is.
You could more than likely sell your auto, and buy a manual for the same price or near it. and Fix anything wrong with it for way less than the conversion cost.
You will need:
clutch and flywheel
torque tube
YMMV,
I'd make sure you can get all the parts first, it can take a while to locate some things like the torque tube and shift boot. I'd also locate a local tuner and discuss a tune to change to a manual.
I'm just saying that the potential problems are less than what some think. And, that there is nothing magical about the trans. Swapping it out is no more damaging to the resale than swapping in a different engine or such.
