cam install
Old Oct 25, 2008 | 09:34 PM
JAMESNORTHPROV's Avatar
JAMESNORTHPROV
Default cam install
anyone have detailed instructions on a cam / double roller timing chain and hd oil pump install. cam has 0 timing ground in, thinking how much to advance the timing. also installing a overdrive h/b . also what would be best way to hold lifters up. thanks fer any help. jim.
Old Oct 25, 2008 | 10:18 PM
fst85vtt's Avatar
fst85vtt
Ls1howto.com
Old Oct 26, 2008 | 08:24 AM
stangbangin69's Avatar
stangbangin69
Originally Posted by fst85vtt
Ls1howto.com
Old Oct 28, 2008 | 01:02 AM
Tourmgr1's Avatar
Tourmgr1
The search function is a great tool but I'll give you a head start with these links.
http://forums.corvetteforum.com/show...php?t=1592160]
http://www.ls1howto.com
http://www.ls1tech.com
Good Luck.
Old Oct 28, 2008 | 05:39 AM
vettenuts's Avatar
vettenuts
You will need a degree kit as well if you are truly going to set it up at 0 degrees. Also, LS1howto instructions for removal/re-installation of the pulley are wrong, don't use them.
As for rods, make them from 5/16" diameter rods available at Home Depot. Just round the inserted end and clean them well.
Old Nov 6, 2008 | 06:43 PM
JAMESNORTHPROV
Default Install
Thanks guy, good info to work with. Jim
To cam install
