NOS
Old Jan 11, 2002 | 03:13 PM
Red C5's Avatar
Red C5
Default NOS
I finally got my first Corvette, my dream come true. I have heard a lot about NOS, some good, some bad. Since so many of you run NOS, I'd like to know if there are any problems that come along with it. Extra service or maintenance, reliabilty, etc. mine is a daily driver, and I do not want to run anything that will create problems. Thanks in advance.
Old Jan 11, 2002 | 03:29 PM
jetskifast's Avatar
jetskifast
Default Re: NOS (PeterC)
N20 is great. You only use extra power when you need it.
For daily driver I would avoid kits that use power ring. Power ring puts solenoids right smack in the middle of your engine heat. Constant heat and cooling of solenoids will cause damage over the long term.
Mounted my solenoids, on front frame section away from engine heat.
Old Jan 11, 2002 | 03:34 PM
shftn6's Avatar
shftn6
Default Re: NOS (jetskifast)
Ummmm, selenoids can be mounted anywhere, even with the power ring.
Old Jan 11, 2002 | 03:39 PM
vettewrench's Avatar
vettewrench
Default Re: NOS (shftn6)
shftn6,
Yes we can mount them any where you want the only problem you will incounter will be a delay in the NOS when it kicks in if you have them to far from the jets.
Old Jan 11, 2002 | 03:40 PM
ElDiablo's Avatar
ElDiablo
If you get all safety things with it then no. The car is stock till you hit that button. Don't get more than 100HP wet :yesnod: You'll need, a kit with bottle warmer, window switch, WOT ot TPS switch and optional eletric bottle oppener and external PSi gauge. Here are some pic's from my install with Corevtte Doctors in NY did.
Look on top of the first pic where the gauge it.
Old Jan 11, 2002 | 03:42 PM
Red C5's Avatar
Red C5
Default Re: NOS (ElDiablo)
But are there any reliabilty issues. Any extra maintenace that will need to be performed on the car?
Old Jan 11, 2002 | 03:43 PM
shftn6's Avatar
shftn6
Default Re: NOS (vettewrench)
Do they get a delay with the NX kits?
Old Jan 11, 2002 | 03:47 PM
shftn6's Avatar
shftn6
Brian,
Anyways I want them mounted like you have on your website. That is the best install I have seen!
Old Jan 11, 2002 | 03:48 PM
2thDr's Avatar
2thDr
How many times do I have to say it? It's not NOS, it's Nawwzzz. The Fast and Furious said so.
Old Jan 11, 2002 | 03:55 PM
jetskifast's Avatar
jetskifast
shftn6
Power ring kits I have seen, had solenoids mounted right on ring.
I also have purge kit, no delay.
Old Jan 11, 2002 | 08:42 PM
Skeeter1's Avatar
Skeeter1
Peter, N20 is a lot of fun, i say get some :D Jetski is mistaken about the power ring, as you can mount the noids any where you wish. get the TNT kit if you want the best kit on the market :yesnod:
Old Jan 11, 2002 | 08:50 PM
MitchellDavidson's Avatar
MitchellDavidson
Default Re: NOS (Skeeter1)
How many of you installed your N20 kit yourself?
Old Jan 11, 2002 | 09:00 PM
CAR WASH KING's Avatar
CAR WASH KING
Default Re: NOS (PeterC)price?
what is a fair price for a nos kit installed??
Old Jan 12, 2002 | 12:53 AM
intel55's Avatar
intel55
Default Re: NOS (MitchellDavidson)
:seeya
Old Jan 12, 2002 | 01:00 AM
Skeeter1's Avatar
Skeeter1
Default Re: NOS (PeterC)price? (c54menu)
I paid $300 for n20 install.
Old Jan 12, 2002 | 01:11 AM
jetskifast's Avatar
jetskifast
Skeeter1
Remember 99 hardtop who used to push TNT power ring and products on this board.
Do you know what happened to his car?
Fire destroyed his car. Last post I saw was fuel solenoid leaked near power ring and totaled car:(
Maybe it is a good idea to mount solenoids away from heat ;)
Old Jan 12, 2002 | 01:15 AM
intel55's Avatar
intel55
Skeeter1
Yeah and he had Tony from TNT in the car with him and James riding behind. I don't recall what the exact cause of the fire was, but it was terrible. I do not think I have seen Dale on here since that time. Hope he got a new ride and is doing well. :cheers:
To NOS
Old Jan 12, 2002 | 01:17 AM
jetskifast's Avatar
jetskifast
MitchellDavidson
Installed complete NX kit :cool:
If you have basic mechanical ability, you will have no problems installing your own N20 kit. Install is simple but time consuming.
Any problems you run into, forum will be there to help out. :cheers:
Old Jan 12, 2002 | 01:20 AM
Skeeter1's Avatar
Skeeter1
anything can happen, maybe your right. I still think the TNT kits are superior, and you can mount the noids like yours if your concerned about the heat, also I dont think it is that much cooler near the radiator as opposed to at the throttle body. :cheers:
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: NOS
Just an opinion about remote mounting of fuel solenoids... it is generally accepted safety practice in automotive design and racing that fuel is NEVER routed ahead of the front crossmember and certainly never outside the frame rails. Some folks have mounted their solenoids on the front rail.. certainly their choice, but if you ever get into a front end collision, the chances of a fuel discharge are greatly increased by having the solenoids mounted to what is in effect, your front bumper.... Lots of folks do it, but I wouldn't even dream of it.. Just my $0.02......NO FLAMES INTENDED !!!!
