After installing my twin turbo kit, my turbo's are leaking serious oil out the tailpipes. The turbo's are brand new master power t 70's. Anybody know what's happening?
Reason: ...
I'm thinking either you have a restriction on the return or your turbo's or th seals are toast. This is a front mount system?? If so, they should gravity drain back to the oil pan with no problem.
I have used master power turbo's several times without any issues. I would check your drains. What size is your drain line. Also what size a/r are you running on the hot side? keep us posted.
It is a top mount setup with the return lines draining into the top of the oilpan. Why would the seals already be toast in these turbo's (there new!!)
I bet you need to put restrictors in the oil feed lines. If you're running a PTK type set-up PM Nick Yoskin as he has a lot of experience with these set-ups.
I was'nt running a restrictor on the turbo's upon masterpower's request that they will hold up to 80 pounds of oil pressure. So i then put a #35 nos jet in the line before the T and still had drainage issues of oil out the tailpipes, probally cause the seals had already blown out from no restrictor. I am running #8 line with a smooth return flow (I Checked) and Master Power said that was my problem, I should have used #10 (not much bigger) So I pulled the turbo's off and sent them back to Master Power to find out what the problem is ? I just hope not to install them upon return and have the same thing happen, any suggestions. Thanks for everyones help REALLY !!!!
Sorry to hear of your misfortune. Oh well nothing like learning the hard way.
That all that I thought was wrong with them. I have used them several times with no issues. When you say #10 line do you mean -10 line? Hope everything goes well with the new turbos.
You should also confirm that you are not getting any pressure in the crankcase. Even a good gravity drain won't drain very well when there's positive pressure in there.
tried to call,
everyone seems to have to go threw this.it is not the turbos.
good .035 restrictors,perfect drain line set up 1 or 2 line.clean out the intercooler!
i put two .125 holes in mine to drain the carb. cleaner i sprayed in fro the top.then pluged with screws.
4-an feed is good.i used a t- line set up to drain with a clear braided hose from lowes so i could see.if it drains level or upwards it will back up.
i also built my alt brk.,too simple to believe
tried to call,
call me ,mike i need help too
I did some reading the other day and saw that -3 was the feed and -12 was the drain.
