Service Engine Light
Old Oct 27, 2008 | 12:48 AM
Varmit's Avatar
Varmit
St. Jude Donor '08
Default Service Engine Light
Every time I start my C5 the "Service Engine" message shows up in the DIC. No codes are shown, no check engine light. Once reset the message stasy of, and it stays off untill it is started again. When the engine is started the message comes up after about 10 seconds. The Oil Life has been reset, but the message continues to come up at each start.
Since I get no codes with the message, I'm lost as to what it can be.
Old Oct 27, 2008 | 06:08 AM
c3andc5's Avatar
c3andc5
Try seeing what code(s) you may have on the DIC. Turn the key to "on" but don't start the engine. Clear any messages. Hold the OPTIONS button down and press the FUEL button four times. That will cylce through all the modules and the codes. Their is a post here that lists all the codes and what they mean.
Old Oct 27, 2008 | 10:11 AM
Varmit's Avatar
Varmit
St. Jude Donor '08
Know how to do that, but there are no historical codes that I do not know what they are.
Old Oct 27, 2008 | 10:44 AM
Varmit's Avatar
Varmit
St. Jude Donor '08
Somebody had to have an idea on this!
Old Oct 28, 2008 | 11:32 AM
Varmit's Avatar
Varmit
St. Jude Donor '08
ttt
Old Oct 28, 2008 | 12:00 PM
lucky131969's Avatar
lucky131969
List the codes you are getting, even if they are history....
Old Oct 28, 2008 | 12:23 PM
FKING1's Avatar
FKING1
Make sure fuel cap is on tight, just a slim chance, has happened to me.
Old Oct 28, 2008 | 07:07 PM
Varmit's Avatar
Varmit
St. Jude Donor '08
Only three under BO RFA....1096, 1064, and 1016 all historical
Old Oct 28, 2008 | 07:08 PM
Varmit's Avatar
Varmit
St. Jude Donor '08
been checked
Old Oct 28, 2008 | 08:04 PM
lucky131969
What's interesting, is that "Service Engine" is not even listed as a possible warning message per the service manual.
Old Oct 28, 2008 | 09:34 PM
Varmit's Avatar
Varmit
St. Jude Donor '08
Ah, therein lies the problem!!!!
Old Oct 29, 2008 | 12:16 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Are you absolutely 100% positive it says "service engine", because I'll bet it says "service vehicle"
Old Oct 29, 2008 | 01:19 AM
Varmit's Avatar
Varmit
St. Jude Donor '08
u r right, but does it really make any difference at this point
Old Oct 29, 2008 | 03:06 AM
ZeeOSix's Avatar
ZeeOSix
From the Owner's Manual ... remember that thing?
DIC Warnings and Messages
SERVICE VEHICLE SOON: If this message appears
on the DIC, there may be an electrical or another system
problem with your vehicle. Have your vehicle checked
by your dealer if this message keeps appearing.
That's all it says ...
Old Oct 29, 2008 | 09:52 AM
lucky131969
Yeah sweetie, it does make a difference. I spent some time looking through the service manuals, trying to find that message.....so I spent some more time, trying to determine if it some how could be year specific, etc. If you want exact help, then be exact.
So, you ask...."does it really make any difference at this point? "
Nope, not to me.....figure it out yourself.....
Old Oct 29, 2008 | 09:55 AM
Varmit's Avatar
Varmit
St. Jude Donor '08
Thanks, but the sweetie thing is a bit much
Old Oct 29, 2008 | 02:49 PM
Bill Dearborn's Avatar
Bill Dearborn
I am posting below the only messages that can appear on the DIC. For each message there is a reference to what subsystem is involved. The list should show you the reason you have to be exact. Service Engine Soon is not one of those messages. It only shows up as Check Engine Light on the instrument panel.
Bill
ABS ACTIVE--Refer to ABS Description and Operation in Antilock Brake System
ACT HNDLG-WARMING UP--Refer to ABS Description and Operation in Antilock Brake System
ACTIVE HANDLING--Refer to ABS Description and Operation in Antilock Brake System
BRAKE BEFORE SHIFT--Refer to Automatic Transmission Shift Lock Control Description and Operation in Transmission
CHANGE OIL NOW--Refer to Indicator/Warning Message Description and Operation
CHANGE OIL SOON--Refer to Indicator/Warning Message Description and Operation
CHARGE SYSTEM FAULT--Refer to Charging System Description and Operation in Engine Electrical
COMPETITIVE DRIVING--Refer to ABS Description and Operation in Antilock Brake System
COOLANT OVER TEMP--Refer to Cooling System Description and Operation in Engine Cooling
CRUISE DISENGAGED--Refer to Cruise Control Description and Operation in Cruise Control
CRUISE SET XX KM/H (XX MPH)--Refer to Cruise Control Description and Operation in Cruise Control
DOOR AJAR--Refer to Door Ajar Indicator Description and Operation in Doors
ENGINE PROTECTION, REDUCE ENGINE RPM--Refer to Powertrain Control Module (PCM) Description in Engine Controls
FLAT TIRE-XX, MAX SPD 55, REDUCED HNDLG--Refer to Tire Pressure Monitor Description and Operation in Tire Pressure Monitoring
HATCH AJAR--Refer to Luggage Compartment Description and Operation in Body Rear End
HIGH OIL TEMPERATURE, REDUCE ENGINE RPM--Refer to Indicator/Warning Message Description and Operation
HIGH TIRE PRESSURE-XX--Refer to Tire Pressure Monitor Description and Operation in Tire Pressure Monitoring
HIGH TRANS TEMP--Refer to Transmission Component and System Description in Automatic Transmission-4L60 E
HIGH VOLTAGE--Refer to Charging System Description and Operation in Engine Electrical
LOW BRAKE FLUID--Refer to ABS Description and Operation in Antilock Brake System
LOW FUEL--Refer to Indicator/Warning Message Description and Operation
LOW OIL LEVEL--Refer to Indicator/Warning Message Description and Operation
LOW OIL PRESSURE--Refer to Indicator/Warning Message Description and Operation
LOW TIRE PRESSURE-XX--Refer to Tire Pressure Monitor Description and Operation in Tire Pressure Monitoring
LOW VOLTAGE--Refer to Charging System Description and Operation in Engine Electrical
LOW WASHER FLUID--Refer to Wiper/Washer System Description and Operation in Wipers/Washer System
MAXIMUM SPEED 129 KM/H (80 MPH)--Refer to Electronic Suspension Control Description and Operation in Electronic Suspension Control
OVER SPEED WARNING--Refer to Powertrain Control Module (PCM) Description in Engine Controls
PULL KEY-WAIT 10 SEC--Refer to Steering Wheel and Column Description and Operation in Steering Wheel and Column
REDUCED ENGINE POWER--Refer to Powertrain Control Module (PCM) Description in Engine Controls
RESERVE FUEL--Refer to Indicator/Warning Message Description and Operation
SERVICE ABS--Refer to ABS Description and Operation in Antilock Brake System
SERVICE ACTIVE HNDLG--Refer to ABS Description and Operation in Antilock Brake System
SERVICE COLUMN LOCK--Refer to Steering Wheel and Column Description and Operation in Steering Wheel and Column
SERVICE RIDE CONTROL--Refer to Electronic Suspension Control Description and Operation in Electronic Suspension Control
SERVICE TIRE MONITOR--Refer to Tire Pressure Monitor Description and Operation in Tire Pressure Monitoring
SERVICE TRACTION SYSTEM--Refer to ABS Description and Operation in Antilock Brake System
SERVICE VEHICLE SOON--Refer to Indicator/Warning Message Description and Operation
SHOCKS INOPERATIVE--Refer to Electronic Suspension Control Description and Operation in Electronic Suspension Contro
TONNEAU AJAR--Refer to Luggage Compartment Description and Operation in Body Rear End
TRAC/ACT HNDLG-ON/OFF--Refer to ABS Description and Operation in Antilock Brake System
TRACTION SYS ACTIVE--Refer to ABS Description and Operation in Antilock Brake System
TRUNK AJAR--Refer to Luggage Compartment Description and Operation in Body Rear End
UPSHIFT NOW!--Refer to Skip Shift Description and Operation in Manual Transmission-MM6
WARM UP COMPLETE--Refer to ABS Description and Operation in Antilock Brake System
To Service Engine Light
Old Oct 29, 2008 | 02:56 PM
KENCO's Avatar
KENCO
St. Jude Donor '11
Correct me if I am wrong, but the service vehicle comes on at periodic intervals for scheduled maintenance items. I had one come on at 98k on another car I had and it was for replacement of plugs, wires and some other things. The mechanic shut it off after they serviced it and it never returned.
Could it be a mileage thing?
Old Oct 29, 2008 | 04:39 PM
Varmit's Avatar
Varmit
St. Jude Donor '08
My bad, it is Service Vehicle Soon. no supporting codes or other info.
Sorry Guys
Old Oct 29, 2008 | 04:42 PM
KENCO's Avatar
KENCO
St. Jude Donor '11
Sorry Guys
Thank you..............Thank you............
