Am i just stupid?
Old Oct 28, 2008 | 06:59 PM
playloudd308's Avatar
playloudd308
Default Am i just stupid?
Okay, i just bought a 99 FRC. I am very happy with the car, it is beautiful. I am just having one little problem. The backlight for my gauges refuses to turn on. I have tried everything. I know they work because they will turn on right after i turn the car off and i had them on last night by turning the key to the right a bit more in the ignition. Am i really this dumb or is there a special trick?
Old Oct 28, 2008 | 08:19 PM
lucky131969's Avatar
lucky131969
Have you tried adjusting the dimmer **** on the left hand side of the instrument panel?
Old Oct 28, 2008 | 08:20 PM
happa's Avatar
happa
Try adjusting the **** on the left side of the dash, it should be the dash light dimmer. Not sure if that will work for yea. Good Luck!
Old Oct 28, 2008 | 08:21 PM
happa's Avatar
happa
Man you beat me by 1 min.
Old Oct 28, 2008 | 08:45 PM
playloudd308
yahh, i have actually moved this to every position possible. i thought it was something to do with a setting through the dic. Idk what it is cus it was working fine last night and i see it turn on when the car turns off.
Old Oct 28, 2008 | 10:17 PM
lucky131969
Do the instrument lights turn on with the headlight switch on?
Old Oct 28, 2008 | 11:11 PM
playloudd308
they dont come on with the headlights. it is the strangest thing i have seen. im sure there are a few more electrical gremelins that i need to take care of also and i just havent found yet.
is there any reason why this would be happening?
Old Oct 28, 2008 | 11:24 PM
fst85vtt's Avatar
fst85vtt
Do your tail lights come on with the headlights? i had a problem with the multi/switch and i lost my dashlights and tail lights ..
Old Oct 29, 2008 | 08:48 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
There is a guy named Bill Curlee on here that is just a genius with these electrical issues.
Try sending him a pm (private message). I am sure he will have some helpful advice for you.
Old Oct 29, 2008 | 09:59 AM
rpm462's Avatar
rpm462
Check the fuse panel under the passenger footwell for fuse #29 I think, believe it's called Diagnostic in the owners manual.
Old Oct 29, 2008 | 12:36 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I"ve heard of this with the headlamp multifunction switch going bad.
Old Oct 29, 2008 | 01:43 PM
minitech's Avatar
minitech
Fuse 29 also gets the footwell lights. If these are out it may be 29.
Old Oct 29, 2008 | 01:55 PM
Numb's Avatar
Numb
Welcome to high technology built by the lowest bidder. Bill Curlee's electrical thread should be required reading for any new Corvette owner... cleaning up the grounds fixed all kinds of problems on my car.
Old Oct 29, 2008 | 03:43 PM
Sinister-one's Avatar
Sinister-one
will it clear up the clunking noise i get down shifting or decelerating ?
Old Oct 29, 2008 | 07:11 PM
playloudd308
the car does not have tail lights either. the brake lights work, as do the turning signals. I am thinking this could be the same problem. All of the other inside lights work, floorboard, door, and mirror lights.
Old Oct 29, 2008 | 07:50 PM
lucky131969
Have you checked minifuse #6 in the instrument panel electrical center?
Old Oct 29, 2008 | 08:00 PM
playloudd308
havent checked that fuse. i will check the fuses here in a few minutes and see if i have any blown.
To Am i just stupid?
