Speed Sensor Wire Part Number?
Old Oct 26, 2008 | 02:29 PM
FASST LN's Avatar
FASST LN
Default Speed Sensor Wire Part Number?
I wanted to get the part number for the wire pictured below. It is the piece that connects to the front hub assembly.
I've got the 1225 code and the female ends, just like Bill Curlee says, are bent and not making good contact. I'm not very good with cutting and splicing things so I wanted to find out what the cost is for the entire wire to be replaced.
Thanks,
-Jeff
Old Oct 26, 2008 | 02:35 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by fasst ln
i wanted to get the part number for the wire pictured below. It is the piece that connects to the front hub assembly.
I've got the 1225 code and the female ends, just like bill curlee says, are bent and not making good contact. I'm not very good with cutting and splicing things so i wanted to find out what the cost is for the entire wire to be replaced.
Thanks,
-jeff
12163714
hth
Old Oct 26, 2008 | 02:39 PM
FASST LN's Avatar
FASST LN
Snikes that was fast!
Thanks!
I'll checkout the pricing on GMpartsdirect.
Old Oct 26, 2008 | 02:43 PM
FASST LN's Avatar
FASST LN
Holy cow! $54 for that!?
It is a friggin' wire for goodness sakes!
What are the options for cutting and splicing a new female end onto the wire. Can I take the wire into a part store and they can most likely find a replacement plastic female end piece?....or is this GM specific and only GM has the correct piece?
Thanks,
Old Oct 26, 2008 | 02:59 PM
LoneStarFRC
Thanks,
It is a "dealer type item" (meaning GM) ONLY, and is more than just a "wire". It is a shielded wire harness assembly that can have a direct impact on how well (or how poorly) your ABS will work.
DO NOT buy from GMPartsDirect. Too expensive.
Contact forum vendor Fichtner Chev tomorrow at 1-800-234-5284 (ask for Bob in parts) or contact Gene Culley at GMPartHouse (also forum vendor). Their pricing will be much better.
Old Oct 27, 2008 | 05:03 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Jeff
I found out (by trial and error) that you can get a small jewlers screw driver and insert it into the FEMALE PIN and pry the "TONGUE" up so that it makes firm contact with the male pin. I have reciently done this on three C5 with excellent results. If the jumper harness is bad, its an easy swap in replacement. If the female connection on the K member is bad, you either need to try to pry up on the female pin tongue or cut and splice the connector with this:
Notice the STEALERSHIP Price RIPOFF!!!!!!
If you need them, get them from Gene Culley At www.gmpartshouse.com
BC
Old Oct 27, 2008 | 01:03 PM
FASST LN's Avatar
FASST LN
I'll try the prying.
Anything to save a buck. Plus, if it still doesn't work, I'm back to where I started. No harm done.
As always, Thanks Bill!!
Old Oct 28, 2008 | 02:37 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The ONLY way to really know if the female connector is making proper contact with the male contact is fitting in a male pin and see how much grip there is on the male pin.
This is what I use. It a male terminal pin out of an emergency flasher switch ( took an old one apart) :
If there is a FIRM grip on the male pin, you will have a good connection. Some auto parts stores and the dealer sell replacement pins. See if you can find one of the same thickness and width.
BC
Old Oct 28, 2008 | 12:18 PM
FASST LN's Avatar
FASST LN
Thanks Bill. I'll give that test of yours a try.
Thanks again!
Old Oct 29, 2008 | 08:58 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thanks for the referrals. I'd be happy to assist anyone who needed help.
To Speed Sensor Wire Part Number?
