pilot bearing install
Old Oct 28, 2008 | 07:27 PM
Jesse_Boyer's Avatar
Jesse_Boyer
Default pilot bearing install
Does anyone know right off hand if the new pilot bearing should be 'flush' to the surface next to the crankshaft or if it protrudes out of the crankshaft slightly? If it's not the ladder, I believe I have a new problem to solve...
Old Oct 28, 2008 | 07:31 PM
KeyWestJack's Avatar
KeyWestJack
Old Oct 28, 2008 | 08:01 PM
KCvetteowner's Avatar
KCvetteowner
The pilot bearing should be flush with the end of the crankshaft as it goes inside the crankshaft.
Old Oct 28, 2008 | 08:05 PM
Jesse_Boyer
definitely have about 1/16" inch of the pilot bearing sticking passed the crankshaft... I wonder what gives?
Old Oct 28, 2008 | 10:29 PM
02gt350's Avatar
02gt350
we have always put them ALL the way in. theres plenty of room
Old Oct 28, 2008 | 10:40 PM
Jesse_Boyer
Looks like I"m headed after the removal tool and pulling this one out again. Something is definitely awry...
Old Oct 28, 2008 | 10:47 PM
02gt350's Avatar
02gt350
are you sure you just dont need to hammer it more?
It takes quite a lickin to get it in there
Old Oct 28, 2008 | 11:58 PM
KCvetteowner
Did the old one come out in one piece? Any chance it didn't and you left something in there???
Also verify you got the correct one.
I placed mine in the freezer overnite and it went in without any trouble....
Old Oct 29, 2008 | 05:24 AM
vettenuts's Avatar
vettenuts
Stock crank?
If yes, did the seal behind the pilot bearing move? How did you remove old one?
Old Oct 29, 2008 | 06:34 AM
Jesse_Boyer
I hammered it pretty hard, but it's still not flush.
I did too! Had it in the super-duper-industrial freezer ( ).
No, it came out with a die-grinder after breaking two pullers. I thought I had everything out behind it, but maybe not...
Originally Posted by vettenuts
Stock crank?
... I was unaware of the 'seal' you speak of. Can you tell me more?
Old Oct 29, 2008 | 09:46 AM
lucky131969's Avatar
lucky131969
There is an oil gallery plug in the crankshaft behind the pilot bearing.
http://www.flickr.com/photos/1545929...91926/sizes/o/
What type of pullers did you use? A pilot bearing puller typically takes care of the job. I would be afraid to use a die grinder around the crank like that.
Old Oct 29, 2008 | 10:15 AM
Jesse_Boyer
I tried the cheesy two-prong pullers, broke two, then went for the air tools.
So, based on the modified drawing below, would you assume that if I can't get the new bearing in with repeated blows with a hammer (assuming it is the right bearing), I have something lodged between the seal and new bearing?
Old Oct 29, 2008 | 10:52 AM
vettenuts's Avatar
vettenuts
That is what I spoke of in my earlier post.
Old Oct 29, 2008 | 11:04 AM
Jesse_Boyer
I thought you wanted to know if the 'seal' itself moved, not something foreign in between the seal and the bearing.
Are you asking if I removed the old seal? If so, I definitely did not. I'm debating pulling the bearing again, and getting a better look at what's behind this thing...
Old Oct 29, 2008 | 11:46 AM
lucky131969
Buy (or rent) the correct tool for the job. You've got more ball$ than me using a die grinder in that area The bearing should be installed flush. I would remove the bearing (you'll have to buy a new one), get the correct three prong puller, and investigate.
Old Oct 29, 2008 | 11:54 AM
Jesse_Boyer
believe me, if I could locate the correct 3-prong puller in the area, I certainly would. I'm probably going to have to order something and have it shipped...
I'll keep investigating. With any luck, I can locate the proper puller and see what's what.
Old Oct 29, 2008 | 12:00 PM
ericdwong's Avatar
ericdwong
I don't have any pics but the "correct" puller is not 2 or 3 prong. It is a device that has a threaded end that expands at the end and grips the pilot bearing from all the way around. Comes out no problem and I've replaced it twice in my car. Those 2 or 3 prong ones are horrible.
I rented mine for free from the local auto parts store.
To pilot bearing install
Old Oct 29, 2008 | 12:06 PM
lucky131969
You are correct, I just checked mine, and it is two prong. Sorry for the confusion.
Old Oct 29, 2008 | 12:16 PM
Jesse_Boyer
Autozone, O'Rielly's, Advanced Auto... only two had pullers for rent and both were the cheesy 2-prong kind.
Old Oct 29, 2008 | 12:51 PM
KeyWestJack
Something like this:
http://www.etoolcart.com/blindholepullerotc4581.aspx
