Fuel filter replacement...
Old Oct 29, 2008 | 02:23 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Fuel filter replacement...
what size tool do I need for the disconnect?
Old Oct 29, 2008 | 02:43 PM
c3andc5's Avatar
c3andc5
This is what I used on my 2000. Bought it at Advance Auto.
http://www.partsamerica.com/ProductD...egoryCode=2109
Old Oct 29, 2008 | 03:13 PM
ericdwong's Avatar
ericdwong
I dunno if the 99's are like the 98's but on my 98, I didn't need a tool at all. I squeezed the 2 tabs with my bare hands and it came right out.
Old Oct 29, 2008 | 05:30 PM
pewter99's Avatar
pewter99
yeah I saw those...I guess they will work on all sizes?? It appears that there are 2 different size connectors based on what I am seeing looking at the filter..
hmm.....that would be
Old Oct 30, 2008 | 05:38 AM
c3andc5's Avatar
c3andc5
Yep, two different sizes on the tool. One side worked perfect on my 2000.
Old Oct 30, 2008 | 09:21 AM
intoc6s's Avatar
intoc6s
If your year is the same as my 2001, its a pressure reg/filter, costs about 40-45 bucks and has two sizes of fuel line connectors on it(a total of three lines on it) - 2 small ones that you can squeeze the tabs and release with your fingers(on the rear of the reg/filter) and one big one(front) that i used a disconnect tool on. If you need the size i ll go out and look at the tool and let u know what size it is.(just pm me to let me know u want me to check for u). I just changed mine about a week ago!- Jason
Old Oct 30, 2008 | 09:22 AM
pewter99's Avatar
pewter99
PM sent
Old Oct 30, 2008 | 09:25 AM
Secret237's Avatar
Secret237
Fuel Filter ??!!??
Where is this fuel filter you speak of ??
Old Oct 30, 2008 | 09:33 AM
intoc6s's Avatar
intoc6s
Originally Posted by Secret237
Fuel Filter ??!!??
Its on the drivers side just ahead of the rear wheel- in the tranny tunnel. Easy to get to in a manual trans- harder to get to with the bulkier sized auto. Its a 3/8"(big line) and the 2 smaller ones on the rear of the filter are 5/16"!-Too tight to get the tool in between the filter and line to release it. Use fingers. Also- U have to swap the plastic tabs off of your old one and install them both on the new one b4 re-installing the new one. Good Luck!
Old Oct 30, 2008 | 09:52 PM
cruisemon's Avatar
cruisemon
If we ever meet at Carlisle or anything, I hope you'll understand why I ain't NEVER gonna shake your hand.
Charlie
Old Oct 30, 2008 | 10:00 PM
lucky131969's Avatar
lucky131969
No, a 99 is not like a 98 in that respect.
Old Nov 3, 2008 | 07:43 PM
Secret237's Avatar
Secret237
Thanks, I'll have to take a look, I don't think I've ever replaced mine !!!
Just never thought of it.
Old Apr 18, 2009 | 01:34 PM
Gbannish's Avatar
Gbannish
I just did mine, and like others have mentioned, the manual transmission (99 FRC) had plenty of room and the job was pretty easy, although gas did spill on my arms (well first onto the exhaust pipe and then onto me!
Greg
Old Apr 18, 2009 | 01:37 PM
pewter99's Avatar
pewter99
Greg
yeah I pulled the fuse for the fuel pump and cranked the car over a bit thus relieving any pressure..spilled maybe a 1/4 cup of fuel.
Old Apr 18, 2009 | 06:02 PM
LoneStarFRC's Avatar
LoneStarFRC
Next time just wrap a rag around the schrader valve on the fuel rail and depress the stem with a small screwdriver to relieve fuel pressure. No fuse pulling, no cranking and you won't even lose near any 1/4 cup of fuel. Easy.
Old Apr 18, 2009 | 06:10 PM
PETE O.'s Avatar
PETE O.
Saves cleaning up the mess.......
Old Apr 18, 2009 | 07:47 PM
7thson's Avatar
7thson
Greg
Same thing happened to me yesterday changing mine. I'm glad exhaust wasn't hot! On a side note I was amazed how hard the old filter was to blow through after 45k miles on car compared to virtually no resistance on the new one. That made me feel better about dropping 50 bucks on a fuel filter..
Old Apr 19, 2009 | 10:52 AM
Redhawg's Avatar
Redhawg
Same here
To Fuel filter replacement...
