I am looking at replacing my harmonic balancer (came loose at a track rental last week) with the SLP balancer. Seems like the exact same thing as the Powerbond balancer. Anyone know if it is?
But my real question is about using the old stock bolt to install the new balancer with. I have read many posts advising not to use the old bolt for anything. However the instructions with the SLP balancer say to use a balancer install tool, then the old bolt to torque the new balancer down to 240 foot pounds and then remove the old bolt install the new bolt. (Using the 2 sequence- of first 37 foot pounds and than 140 degrees)
So either use the old bolt in the installation or not?
Thanks!
The SLP instructions are right on with the service manual...what's the confusion?
I read many posts on this forum about this subject stating never to use the old bolt for anything other than a paper weight -
You don't want to reuse the old bolt for the new installation. If you look in the instructions, it specifically tells you to use the old bolt to seat the balancer at 240 ft lbs(after using the installation tool to press it on the crank). Then you remove, and discard, the old bolt. Insert the new GM bolt, torque to 37 ft lbs, and then to 140 degrees.
Problem is, some guys try to cheap out, and actually used the old bolt as an installation tool, or used the old bolt for the new balancer. Neither of which are permissible.
As LDB C5 pointed out, you can also go with an ARP bolt, which is reusable.
I guess using the old bolt as the installation tool puts more stress on it than just applying 240 foot pounds to it during that phase. It would suck for it to snap in the crank snout.
Thanks for the input.
Yep, or strip out the threads in the crank. Some guys have done it.
Go over to LS1tech and type in crank or balancer tool. There is a guy that sells a nice tool for like $50. Works great.
The factory crank bolt (like the factory head bolts) are "Torque to yield". That's why there is a torque spec AND then a specified number of degrees past that point. I would not even use the old bot to seat the balencer. If it snaps in the crank, you could be in for lots of fun getting it out.
I got lucky when I installed mine, using a slightly longer bolt from the hardware store as an initial installation tool, to get plenty of thread bite when starting it on. I was very careful; heated the balancer to 200 in the wife's oven, threw an ice bag on the crank, oiled the crap out of everything; and it started right on with minimal effort. Once started for about 5 turns, I switched to the old crank bolt and did the 240 lbft thing; then installed a new bolt per instructions.
But..... after reading about stripped threads here, and the availability of a reasonably priced install tool now, I think I wouldn't take that chance again.
But.... if you do decide to try the bolt method, please do all the things above, and take it slow and easy.
Never use the old bolt. The bolt used by GM is designed to strech when it was originally installed and tightin and when you reuse it it has already been streched out and will not tighten again it will always be loose
