Check engine light
Oct 29, 2008 | 11:30 PM
Check engine light
I just put on an aftermarket exhaust and now the check engine light is on,is there something I need to do to take care of this.Or has anyone else had this happen.And what took care of it? Thanks MIke
Oct 29, 2008 | 11:49 PM
Quote:
Originally Posted by
vettemiker
Post your codes.
Oct 30, 2008 | 10:19 AM
St. Jude Donor '14-'15
What kind of exhaust? Cat back? Headers? Is the exhaust with or without catalytic converters?
Oct 30, 2008 | 10:41 AM
What did you do w/ your O2 sensors?
Oct 30, 2008 | 11:17 PM
RE exhaust
I only installed new mufflers and over the axle pipe,did not touch anything else.
Oct 30, 2008 | 11:59 PM
Nov 1, 2008 | 10:01 AM
Re codes
p0740hc,po748hc,po753hc,po758hc,po785hc, p1860hc,any help would be appreciated. Thanks Mike
Nov 1, 2008 | 11:53 AM
These are all Auto Transmision codes. I sugest you check the wireing harness and connector to the transmision.
