Blackwing install question
Old Oct 31, 2008 | 06:09 PM
lane124's Avatar
lane124
Default Blackwing install question
New guy here with a question. I bought the Blackwing CAI
to install on my 2001 C5. How does one using the supplied
3.75x2 straight sleeve to connect the air filter to the mass
air sensor get everything to line up right so you can
push the the grommets onto the studs and get the bellow
to line up with the throttle body? I'm not having much
success at the moment. Pictures to this process would
have been nice with the instructions they gave.
Thanks,
Chris
Old Oct 31, 2008 | 06:22 PM
jeff49's Avatar
jeff49
I had the same problem.I trimed the black sleeve to the proper length.I hooked everything up then measured the sleeve and trimed.I hope this helps
Old Oct 31, 2008 | 07:00 PM
hotwheels57's Avatar
hotwheels57
Align everything together on the TORX pins/grommets w/o tightening the clamps except at the throttle body. Trim after measuring twice.
Then I got intermittent lean codes and eventually removed the "Blackwing"...
Old Nov 1, 2008 | 11:51 AM
lane124's Avatar
lane124
Thanks for the help. I didn't want to start cutting and screw it up without posing
the question before hand. I put the assembly together in my den. Measured the
sleeve such that the blackwing opening and the mass air sensor were touching then cutoff the extra sleeve. It ended up being roughly 9/16 inch of sleeve I cutoff. Put
it back on the car and it fit perfectly.
To Blackwing install question
