Lifting car to remove wheels...What do I need?
Old Jan 12, 2002 | 10:46 AM
C5XTASY's Avatar
C5XTASY
Default Lifting car to remove wheels...What do I need?
I'm thinking about painting my calipers. Now, to lift the car I obviously need a floor jack but beyond that what do I need?
1) Can I use the rear shackles as lifting points for the rear?
2) Do I need ramps to get the front of the car high enough to slip a floor jack under it?
3) Do I need lifting pucks to use on the front end lift with the jack?
4) Do I need jackstands?
Any information would be appreciated. I don't know, but assume that most do two wheels at a time. Thanks!
Ed
Old Jan 12, 2002 | 11:20 AM
MJM's Avatar
MJM
Default Re: Lifting car to remove wheels...What do I need? (C5XTASY)
NO, check the owners manual it has the lifting points in it. For the rear it is either side of the center brace, preferably where the flanges all come together and there is kind of a circle there. (that sounds really confusing but when you see it, you'll understand, there is a diagram in the owners manual)
Yes, Rhino ramps work great and don't cost much.
Not really, as long as you place a wood block or something similar between the metal lifting end of your jack and the car itself. This spreads the load and keeps from damaging the car.
Always use jackstands when working under a vehicle.
[quote]Any information would be appreciated. I don't know, but assume that most do two wheels at a time.[quote]
I actually have two sets of jack stands so that I can get the entire car up in the air at the same time. This helps when bleeding brakes or doing other preventative maintainence at the track.
Have fun,
Matt.
Old Jan 12, 2002 | 11:40 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Re: Lifting car to remove wheels...What do I need? (MJM)
I agree with what MJM said.
but you could also use a newspaper ( the complete folded up newspaper)
instead of jacking pucks or wooden blocks.
I worked great for me when I did my rotors and Z06 calipers.
the newspaper is soft so It will not hurt the body, and when it is folded up is very strong. It also distributes the weight nicely.
plus it's a whole lot easier to find than a piece of wood that's the right size. :D
To Lifting car to remove wheels...What do I need?
