Check the torque on the rear axle nuts. They have a tendancy to loosen and cause clunking when starting out or changing directions. Lots of posts on here about fixing.
Loosen nut, loosen wheel nuts, jack tire off ground, remove wheel, Remove nut, push in on axle, lube axle splines from back side, reinstall nut, reinstall wheel, lower and torque wheel and axle nut.
Found my left rear loose, fixed by above procedure.
I would recommend you make a run to the dealer and get a bottle of limited slip additive and put it in or you'll be in the same boat as I was.
Well I was wondering what ratio the RP was blended at. Did you notice the clunking immediately after you filled her up or was it more of a progressive thing. I did not add any limited slip. However, through every test I know how to perform, I got no clanking or clunking. I have been following your thread because I am having leakage issues. Just havent been able to find it yet.
The groaning and clunking sound was more progressive and not immediate. And I don't know what the blend ratio is either, but I can tell you from my experience, they need to add more additive to their gear oil.
Originally Posted by C5SCCA
I will add some on your advice. I would rather there be too much, than not enough.
BAD idea.
Adding too much is not the answer and will negatively affect how the limited slip differential clutch packs do their job. Too much and you run the risk of becoming a "peg legger".
The amount of LSA should be ONLY enough to prevent the clutches from chattering when turning, and NO more. If you're not experiencing chattering issues now, leave it alone.
HTH
What? You mean more isn't better.? What about more cowbell, you can never have enough cowbell in a song...right?
HTH
OP stated noises were progressive and not apparent during the beginning. I added approximately .5-.75 of an ounce of LSA. No peg leg. No chatter.
Sounds like your addressed your particular situation correctly. By adding LSA in JUST enough small dose(s) to solve any clutch chatter is the way to go, as LONG as any sounds/symptoms being experienced are not being confused or misinterpreted for some OTHER actual underlying problem. Often, "diagnosing" something based on the particular "sound" (or other symptom) is extremely difficult, if not confusing. Just ask any service writer at a dealership or repair shop.
That's why I would HIGHLY recommend checking into the axle/bearing matter FIRST, as it's more likely and tends to be a bit more common, and once someone just dumps an additional bottle into their diff (4 oz.), and turns out to NOT be the problem, then now they are faced with draining the diff fluid and starting there all over again (if they're even smart to recognize that fact), not to mention that the original "problem" still exists.
I have had the RP Maxgear in my diff for well over a year now and not one issue. I did not add any additional LSA. I noted your leakage issue. I read somewhere that you need to be careful not to overfill the diff as it will have a tendancy to blow some of the fluid out the vent under hard acceleration. You might want to check that as possible cause for leakage. Good luck with it.
Thanks for your response. I am glad to hear you have not had any issues. My car was overfilled when I bought it. Way overfilled. I guess that is the dealerships for you. My main concern was that the Maxgear LSA additive was insufficient for the Corvette. It is not an application specific product. I have searched the website to find what it is blended at without luck. I added a very minuscule amount. So far I have not had any leakage issues.
I have had an ongoing noise that sounds like the one that has been decribed here. I went to the dealer and they drained and refilled the differential with what I asuume is the right lubricant. The noise did not go away. This noise never happens at speed but when I turn left from a dead or slow stop.
They sent me a copy of a tech bulletin #PI01369. Which describes what ends up being a weak weld on a gusset. Have any of you fine vetters heard of this before?
