C5 rear differential
Old Nov 3, 2008 | 09:01 AM
Sinister-one's Avatar
Sinister-one
Default C5 rear differential
Okay first off.
I was going to change out my rear end gear oil yesterday and noticed I didn't have the correct size hex head key. Can anyone tell me what size I'll need to buy ?
Secondly.
I have a nasty sound coming from the rear... binding, groaning sound when I make tight or even slight turns. It also make a strange "clunk" sound when I take off and sometimes between gears. I noticed my drivers side tire is worn in middle and the other rear tire is fine....
Any ideas fellow Vetter's ?
Old Nov 3, 2008 | 09:52 AM
Smoove
Guest
Posts: n/a
10 MM
alan head
And your clutch packs are probably bad/going bad. Unless your having driveshaft issue(rubber couplers)
Old Nov 3, 2008 | 10:21 AM
T_Vert's Avatar
T_Vert
Don't think the clutch packs would cause a thump on acceleration. Maybe backlash in the diff or play in the input to trans shaft? Or maybe play in the gears in the trans.
Dave
Old Nov 3, 2008 | 10:22 AM
Sinister-one
10mm seems awfully small... you sure about that ?
Old Nov 3, 2008 | 10:26 AM
Sinister-one
I know I need to change out the diff's gear oil and add some limited slip additive and that should clear up the noise when turning... I still can't figure out the thumping noise.....
Old Nov 3, 2008 | 10:30 AM
lucky131969's Avatar
lucky131969
Small compared to what? Go buy yourself a set of metric hex keys, 10mm is typically the largest in a 9 piece set. Usually a whopping $10.
Old Nov 3, 2008 | 10:48 AM
Sinister-one
Small compared to the allen head size hole I saw in the drain and fill plugs.
Old Nov 3, 2008 | 10:51 AM
lucky131969
I'm not trying to be a smart a$$, but did you measure the hex plug across the flats?....or do you have a Steve Austin eye? To my knowledge, it's a 10mm, which includes my own experience.
Old Nov 3, 2008 | 11:00 AM
Sinister-one
Steve Austin eye !!
Good one bud ! Sorry no BIONIC eye here. Just my prospective from laying on the concrete floor.
okay, 10mm it is. I'll be going by Sears to get my BIONIC 10mm allen head socket.
Old Nov 3, 2008 | 11:06 AM
lucky131969
Steve Austin eye !!
LOL....I was hoping someone would get that one.....kinda dating myself with that joke though.......
Old Nov 3, 2008 | 11:14 AM
Sinister-one
Yeah, you and me both lucky !!
Old Nov 3, 2008 | 11:15 AM
C5SCCA's Avatar
C5SCCA
Depending on your history with the car, the turning clunk issue could be from a lack of limited slip diff additive.
Old Nov 3, 2008 | 12:20 PM
Sinister-one
this I will be taking care of today.
Old Nov 3, 2008 | 09:33 PM
Sinister-one
changed out rear gear oil and added fresh limited lip additive. the groaning and binding noise is gone.
Now anyone have any ideas about the clunking slack sound ?
Old Nov 3, 2008 | 11:29 PM
thetaxman's Avatar
thetaxman
CV joints are a strong possibility
Old Nov 4, 2008 | 08:56 AM
Sinister-one
Hhmmmm........ that one never came to mind.
Time to jack up the car and pull the rear tires, AGAIN !
Old Nov 4, 2008 | 03:21 PM
mellowyellow01vert's Avatar
mellowyellow01vert
My '01 with 32k miles is making an occasional clacking sound from the rear also. I had the tranny and diff fluid replaced with Redline but the noise is still there, occasionally. Let me know what you find out.
Thanks,
JB.
To C5 rear differential
Old Nov 4, 2008 | 03:40 PM
Sinister-one
Thanks,
JB.
make sure the redline gear oil has enough limited slip additive in it. you may have to add some extra.
Old Nov 4, 2008 | 04:06 PM
SUPERCRUZ's Avatar
SUPERCRUZ
Do a search in the C5 Tech section on rear diff noise. I seem to recall several posts regarding popping or creaking from the rear axles during tight low speed turns like in a parking garage. I believe the issue was the rear hubs limited free play and binding on the axle shaft splines. The fix involved removing the rear axle nuts and moving the rear hubs in and out on the axle splines and shooting some lubricant onto the splines. I believe some used lithium grease and others synthetic motor oil or some other type of penetrating lubricant in a can. You will then need to re-tiighten axle nuts to the proper torque specs.
As for the diff, drain it and then refill with a quality synthetic 75W90 gear lub i.e. Royal Purple MaxGear or Amsoil. Add the proper GM limited silp additive for extra insurance. I changed mine in my driveway and did not put the limited slip additive in as the RP Maxgear already has it built into the gear oil. No issues with mine. Others will tell you to add the GM limited slip additive no matter. Good luck with your issue and hope this info helps.
Old Nov 4, 2008 | 04:55 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by SUPERCRUZ
Do a search in the C5 Tech section on rear diff noise. I seem to recall several posts regarding popping or creaking from the rear axles during tight low speed turns like in a parking garage. I believe the issue was the rear hubs limited free play and binding on the axle shaft splines. The fix involved removing the rear axle nuts and moving the rear hubs in and out on the axle splines and shooting some lubricant onto the splines. I believe some used lithium grease and others synthetic motor oil or some other type of penetrating lubricant in a can. You will then need to re-tiighten axle nuts to the proper torque specs..............
On the gear lube matter: Amsoil Severe Gear synthetic gear lube, like RP MaxGear, also comes with limited slip additive already in it.
