Ignition coil question mounting question
Old Nov 4, 2008 | 10:27 AM
OhioC5's Avatar
OhioC5
Default Ignition coil question mounting question
My vette is a 97 with the perimeter bolt valve covers, I bought the 99-04 center bolt valve cover style heads (Ported and polished 5.3's). Does anyone know if the coil brackets for 97-98 are the same as 99-04? If so, will the 97-98 coils mount to the 99-04 brackets?
Old Nov 4, 2008 | 01:08 PM
LoneStarFRC's Avatar
LoneStarFRC
I thought the coils on the '97s and '98s mounted directly to the valve covers w/o a bracket.
Pretty sure you're going to need to get coil brackets.
HTH
BTW, the coils are the same and should be no problem mounting.
