system charge default code??? z06 dies on highway
Old Nov 4, 2008 | 02:46 PM
billywallstreet73's Avatar
billywallstreet73
Default system charge default code??? z06 dies on highway
Hope someone here knows whats up.my car is an 02 z06 stock.I was driving normal at 65 mph on the highway when my car just had the rpms go haywire and then the power cut and it slowly died as I pulled off to the side,the code system charge failure came up.It ended up stalling out completely once I made it to a stop and then I turned it back on and drove home without the problem.Anyone else ever have this happen or know what the problem would be? Thanks
Old Nov 4, 2008 | 02:53 PM
byronhunter's Avatar
byronhunter
Check out the stickys at the top of the C5 tech page. Bill Curlee lets everyone share his elec knowlege, it's good, and it's free.
Old Nov 4, 2008 | 02:57 PM
billywallstreet73
I noticed a few threads where people had this happen while starting the car,but this was after driving for 15 minutes normal on the highway,it was scary having the power cut out at those speeds,the battery was replaced a few weeks ago with an optima if that matters.
Old Nov 4, 2008 | 11:58 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check the door wiring harnesses connectors inside the ubber accordion tubes between BOTH doors for bare wires and corrosion.
There are literly 500 post on this very subject! Bet ya a cold one thats the issue!
BC
Old Nov 5, 2008 | 10:15 AM
billywallstreet73
I noticed the ground wire 104 by the battery harness had some rust and corrosion from my battery I had replaced which was leaking a month ago.I took the wires off and tried cleaning them.I havent taken the car on the road yet.Could that have caused my car to lose all power on the highway?
Old Jan 27, 2011 | 06:45 PM
rjs96gt's Avatar
rjs96gt
My 2002 Z06 just did the exact same thing as the original post yet it would not start up afterwords. I have it at the perfomance shop I go to. I will let you know if the door wiring harnesses were the problem on mine.
Not trying to dig up an old post but this was good info. Thank you Bill!
Old Feb 18, 2011 | 11:57 PM
rjs96gt's Avatar
rjs96gt
Mine ended up being two valve spring failures fyi.
To system charge default code??? z06 dies on highway
