Unlocking steering wheel with no chip key...
Old Nov 4, 2008 | 04:57 PM
ttbestas's Avatar
ttbestas
Default Unlocking steering wheel with no chip key...
i bouhgt 99' frc, the battery was died. the stearing wheel is locked. the previous owner told me that stearing colum lock recall was performed. i called chevy and they confirmed that there is no recall needed to be done and the girl confirmed about two colum lock recalls performed on my car. I have only this valet key bellow. my plan was turn the ignition lock to on position and disable vats with hp tuners to start the car, cause i have no ignition key. but now i stuck. i can open doors glovebox but i wont turn the ignition lock, the stearing wheel is locked. where you think is the problem here. thanks
Old Nov 4, 2008 | 05:02 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
Take your registration and ID to the dealer. They will make you a new key. There is no other option. You won't find anyone on a forum board to tell anyone how to bypass security in our cars. Someone may use it to steal a car.
Old Nov 4, 2008 | 05:11 PM
ttbestas's Avatar
ttbestas
thats my problem i have no dealer around me, you may wanna check this thread i started a while ago http://forums.corvetteforum.com/show....php?t=2161659 ...if you know the answer you can pm me. thanks
Old Nov 4, 2008 | 05:17 PM
ttbestas's Avatar
ttbestas
and this thread is not about the security i think. I just wanna know if i have problem with the recall. and another quastion is. are you able to turn ignition lock to on position( not talking here about starting the car) with valet key.
Old Nov 4, 2008 | 05:24 PM
timemender's Avatar
timemender
See my post #45 in your other thread.
http://forums.corvetteforum.com/show...2161659&page=3
Good luck in your quest. I think that you must go through proper channels to get the correct ignition key through the dealer.
Old Nov 4, 2008 | 05:35 PM
ttbestas's Avatar
ttbestas
ye... to bad proper channels are in diferent countrys. ill try to buy used ignition lock and key from flbay and install them. thanks for your help and sorry for this double thread. i will post later about what success i have
Old Nov 4, 2008 | 06:01 PM
Bill Dearborn's Avatar
Bill Dearborn
Not sure why the steering wheel is locked the non-chipped key (it isn't a valet key) will allow you to turn the ignition lock but will not allow the car to start. I doubt HP Tuners will help you as the BCM controls the antitheft logic and sends signals to the PCM over the data bus. After shorting out the Antitheft Deterrent Relay you would have modify the PCM code so it would turn on the the fuel injectors in the absence of a correct message from the BCM. This means patching software and isn't the same as modifying tables to get a different tune.
Bill
Old Nov 4, 2008 | 07:43 PM
ttbestas's Avatar
ttbestas
thanks for your answer, so who i have to believe now, the guy before said its not possible to turn ignition lock to "on" position with my key, you said its possible, so the problem should be in the colum lock then. i have to figure out how to unlock it, service recall was performed, so here i have no clue. if i would get that key to "on" position then i probably could relink VATS on PCM. i found this information in the foloving thread, please tell me if im wrong here......
http://www.hptuners.com/forum/showth...highlight=vats :
Relink VATS
This feature allows the VCM to relink with the vehicles security system. It is only required on vehicle fitted with Serial VATS systems. It can be used when a new PCM is used in a vehicle or after reflashing a new operating system into a PCM from a different vehicle.
Procedure
To relink the VCM with the BCM please use the following steps:
Plug the interface cable into the vehicle OBD2 port and PC serial/USB interface. See Connecting to the Vehicle section for more information.
Open VCM Editor and select "Relink VATS" from the "Flash" menu. The Relink VATS form will appear.
Put the key in the ignition and turn to the ON position (do not start the vehicle).
Wait 10 to 15 seconds.
Press the Commit button when ready.
Wait for the procedure to complete.
Turn Ignition off for 30 seconds.
Turn Ignition on for 30 seconds.
The vehicle has now relinked the VCM to the BCM.
Relink VATS Rules
The following checks are in place when using the Relink VATS function:
You can relink VATS on vehicles with serial VATS system.
You can relink VATS on any vehicle supported by HP Tuners.
You do not need an individual license for the vehicle.[/QUOTE]
Old Nov 4, 2008 | 08:55 PM
lionelhutz's Avatar
lionelhutz
OK, the non-chipped key should turn in the ignition if it is cut correctly.
The column lock is a motor controlled by the BCM that is unlocked when the key is turned on. Not positive but I would assume the BCM needs to also see the correct key pellet vefore unlocking the column. The column lock has nothing to do with the ignition cylinder - the column lock locks the steering wheel.
Changing the lock cylinder will not allow the car to start. I believe there is a procedure similar to what you posted to re-link the security to a new key.
The PASSkey pellet can be figured out with a resistor decade box or a test box from GM (or buying the correct resistors). I've figured the key pellet out a few times for a friend who buys cars at the smashed action and they don't come with keys. There are just something like 15 different resistor values.
Peter
Old Nov 5, 2008 | 05:14 AM
ttbestas's Avatar
ttbestas
can someone confirm that the Courtesy tm key can turn ignition lock to "on" position( not talking here about starting the car) on 99' corvette when the stearing wheel is locked. thanks
Old Nov 5, 2008 | 12:34 PM
ttbestas's Avatar
ttbestas
Peter
Peter,
its original key, it locks opens all locks. it wont turn ignition lock though. is that normal for all 99' cars or i may have defective key? thanks
Old Nov 5, 2008 | 01:21 PM
byronhunter's Avatar
byronhunter
Did you read timemender's post in your other thread???????????????????
Old Nov 5, 2008 | 02:01 PM
ttbestas's Avatar
ttbestas
yes i did, i even pmed him(no answer yet), cause after him couple guys posted here that my key should turn the ignition lock no problem, so who to believe now. i'm just looking for confirmation from 99' owners if they can turn the ignition lock to "on" with theyr "wallet" key. thanks
Old Nov 5, 2008 | 03:24 PM
byronhunter
After reading the door lock cylinder coding note in the service manual, we need to see a picture of that "courtesy key."
Old Nov 5, 2008 | 03:41 PM
ttbestas's Avatar
ttbestas
here you go. i posted more pics in the first post as well. that key was my hope to solve all the problems...
Old Nov 5, 2008 | 03:54 PM
byronhunter
My '02 service manual says, Ign lock uses 10 tumbler positiond and for the door locks only require positions 6 through 10. That would be the 5 positions closest to the tip of the key. So my guess is Timemender is correct.
Old Nov 5, 2008 | 03:59 PM
ttbestas's Avatar
ttbestas
very good logical explanation, thanks.
To Unlocking steering wheel with no chip key...
Old Nov 5, 2008 | 04:00 PM
Bill Dearborn
To verify what I mentioned in my above post I just taped over the key for my car and tried it out in the car. With tape covering the chip the key will turn the ignition lock but it will not unlock the column.
I do know the courtesy key on my 97 would turn the ignition lock.
Bill
Old Nov 5, 2008 | 04:04 PM
byronhunter
Bill, can you tell from his picture how many cuts were made in that key?
Old Nov 5, 2008 | 04:08 PM
ttbestas's Avatar
ttbestas
hm...i'll take better pic in a sec
