2002 c-5 trunk lid
Old Nov 6, 2008 | 04:11 PM
jim goodyear's Avatar
jim goodyear
2nd Gear
Default 2002 c-5 trunk lid
when trunk button is activated the trunk releases but lid will not pop up very far. usually I opeon and shut door using air pressure to opeon lid or get my girlfriend to break her fingernails getting underneath the lid to pull it opeon. Is there an adjustment I can make or do I need Knew struts and if so wheres the best place and cheepest place to go?
Old Nov 6, 2008 | 04:34 PM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
No, you don't need to buy a bunch of new parts. Easiest thing to do is lubricate the latch assembly and pivot points with WD-40. You can also adjust the two rubber cushions on the rear corners of your trunk lid. Screw them out 1/4 turn at a time, close lid and inspect for level fit with the fenders.
You can also buy or make a spring assembly (trunk-popper) to further assist the release.
Old Nov 6, 2008 | 04:37 PM
kikicorvette's Avatar
kikicorvette
Old Nov 6, 2008 | 05:35 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
very easy to fix yourself, but a more permanent alternative is the trunk popper kit, as suggested above.
I put this on mine, and will never have to worry about this issue ever again. Cost all of $15 and even comes with the right Torx screwdriver to do the job. This screwdriver happens to work in many places on the C5, as I've found out...
www.c5trunkpopper.com
Old Nov 6, 2008 | 08:16 PM
gtzy's Avatar
gtzy
http://forums.corvetteforum.com/show....php?t=2083484
Old Nov 6, 2008 | 08:34 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
I have a trunk popper on my car.
Works great!
Old Nov 6, 2008 | 10:02 PM
NeoZ06's Avatar
NeoZ06
WD-40 is a penetrating oil that CLEANS and PREVENTS RUST but is not a good lubricant...
White lithium grease would be the proper lubricant that is water proof! give it a shot and you'll see...
Old Nov 6, 2008 | 10:33 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
I had the same problem with my trunk. I fixed it for about $5 in parts using Forum member DeeGee's instructional post in the attached thread. Post # 16.
http://forums.corvetteforum.com/show...540&highlight=
The pack came with 2 big springs in it so I made an extra.
To 2002 c-5 trunk lid
