Power lock button not working
Old Nov 7, 2008 | 11:39 AM
nickolbag's Avatar
nickolbag
Default Power lock button not working
Drivers side power lock button is acting up. The unlock works fine but I have to hit the lock button a few times for it to work. I'll be taking the door panels off soon to replace my stereo and figure I should address this issue while I have it apart. So what should I look for? A bad contact patch? Should I just replace the switch?
Old Nov 7, 2008 | 11:51 AM
94legaleagle's Avatar
94legaleagle
my guess is that it is the circuit board going bad - mine does the same thing, except my LOCk works fine, but the unlock gives me problems sometimes - there is a write up where you can unsolder / solder the relay for the UNLOCK, but I DON'T know if you can do the same for the LOCK problem - seems to me that the lock and unlock relays are different, and that the UNLOCk relay can be replaced, but that the lock one cant???
Old Nov 7, 2008 | 04:27 PM
FKING1's Avatar
FKING1
there is a thread about replacing the lock relay. Do a search. I have the same prob.
Old Nov 7, 2008 | 08:54 PM
nickolbag's Avatar
nickolbag
so it look like im going to have to replace it.
curious, possible to replace the drivers side with the passenger side?
Old Nov 8, 2008 | 11:04 AM
Bakersfield's Avatar
Bakersfield
No need to replace it. Follow the instruction here in this link and you can fix it yourself.
http://forums.corvetteforum.com/c5-g...w-problem.html
If you can't solder or you don't want to fix it yourself, send me your door control module and I will fix it for you. Send me a PM for details.
To Power lock button not working
