C5 Shock Question
Old Nov 8, 2008 | 09:13 AM
C5Pat's Avatar
C5Pat
Default C5 Shock Question
My o2 Vert has a squeek in the back end, like rubber on rubber. It's more noticable in the colder weather. The shocks seem fine as far as handling and rebound, but on rough roads there is a fairly loud thumping noise. Bought the car used so I don't know if they were ever changed. Does this sound like a shock replacement job??
Old Nov 8, 2008 | 10:42 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check your sway bar bushings.
BC
Old Nov 9, 2008 | 12:41 AM
JCSZ51's Avatar
JCSZ51
Cruise-In IX Veteran
Yep you need to lube your sways, had to do mine a few months back.
Old Nov 9, 2008 | 09:22 AM
C5Pat's Avatar
C5Pat
Under further investigation, the squeek seems to be coming from the front, But probably the same solution. A silocone spray should do it I persume... Thanks Guys
To C5 Shock Question
