Pilot Bearing with A4?
Old Nov 8, 2008 | 07:44 PM
Choreo's Avatar
Choreo
Default Pilot Bearing with A4?
The dealership is in the process out swapping out LS1 engine in my 2001 right now. The new long block that came in from Scoggin-Dickey has a pilot bearing installed in the crankshaft. The LS1 that came out of my A4 did not have a pilot bearing installed.
The dealership said that the new engines come set up with a pilot bearing installed assuming that they are to be used in a Manual transmission application. The dealership is planning on leaving the pilot bearing installed and said it will not interfere with the torque tube spline that I currently have with my automatic... is that true?
Old Nov 8, 2008 | 08:05 PM
Patches's Avatar
Patches
Never really thought about it but I don't think it would be a problem. I've done both and the A4 shaft doesnt appear to extend quite as far. The spline would not engage the bearing anyway as it's too far back on the shaft. Here are a couple of shots of the A4 when I pulled the tt last year.
Old Nov 8, 2008 | 08:16 PM
tiojames's Avatar
tiojames
I have not had a C5 apart yet, but any auto has to have some type of bushing to center the input shaft of the tranny to the engine. I would ask to see the old engine and look at the difference. If I remember correctly, the pilot bearing can be pushed too far into the engine an will cause oiling problems and leaks.
Rconce01's Avatar
Rconce01
iNTERESTING! I am in the middle of a major tear down in which i am putting solid couplers in there. Max which is one of the guys here on the forum recommened i put a pilot bearing in to help center this thing once i soidify it with the aluminum couplers...but like you mentioned there is no pilot bearing in there and i think it serves no purpose in the A4 setup.... i have pics that llok just like those you posted.
By the way make sure you are not running those soft bmw couplers..mine went bad they look new yet they have .200 inches of runoff and they rub like crazy!
Old Nov 8, 2008 | 08:18 PM
Rconce01's Avatar
Rconce01
those splines and that square clamp center it??
am i wrong
Old Nov 8, 2008 | 08:42 PM
lucky131969's Avatar
lucky131969
All aboard the speculation express......
Old Nov 8, 2008 | 08:43 PM
Patches's Avatar
Patches
Correct. The splines and clamp are the connection. The SM procedure is to run the car at idle or low speed for 10 minutes or so with the clamp loose to allow the shaft to center before it's torqued. Check it out.
Old Nov 8, 2008 | 08:58 PM
Rconce01's Avatar
Rconce01
great! yeah thats the way i have done it in the past.
By the way do the manual vettes have that clamp?
probably not that why they need a pilot bushing
Old Nov 9, 2008 | 08:34 AM
Patches's Avatar
Patches
Manual pilot shaft is supported by the bearing while the spline resides in the clutch and in front of the slave cylinder. No clamp as in the A4.
To Pilot Bearing with A4?
