Speedometer Pulse Type?
I'm CONSIDERING adding an aftermarket hud system to it, but the unit in question is compatible with 2,4,8,and 16 pulse types. (most vehicles are 4 pulse) Honestly, I don't even know what this is.
Next, Does the ECU have a speed sensor signal? I'm sure it does but these are all required for the system to operate.
Seems like a pretty cool gadget, but I'm not quite sold on it yet.
here is the link: http://www.defi-shop.com/sports/spotsfrm.htm
:confused: :confused:
[Modified by NoVector, 3:24 PM 1/13/2002]
One more thing, the speed sensor signal input to the PCM is 7/C1 (High) 0.35 YEL wire and 71/C1 (Low) 0.35 PPL wire. This signal is from a magnetic pickup sensor so if you want to tap it you need to use a simple high gain comparator attached to the 7/C1 0.35 YEL wire. Use the comparator output to connect to whatever you need a speed signal to, the signal will be a frequency that follows the vehicle speed.
I hope this gives you some ideas. :cheers:
[Modified by seanr, 10:42 PM 1/13/2002]
It also says that the speed sensor is as you would expect on the differential.
Connector C1 is red.
Anyone know what pulse rate it is?
BTW, where can I pick up one of these service manuals? Sounds like there is some good info in there.
Thanks for the help. :cheers:
They are definately worth having :cheers:
