Fuel pump does not come on during first crank
Old Nov 12, 2008 | 05:50 PM
WardVette's Avatar
WardVette
Default Fuel pump does not come on during first crank
Hi,
I noticed that my 99 Corvette would not start until the second or third try. While looking for other symptoms, I noticed that the fuel pump was not coming on during the first crank and sometimes during the second crank. It also has zero fuel pressure during this time. My workaround has been to just cycle the key to "On" and then to "Off" two or three times until I hear the fuel pump, and then it starts right up. Anybody know what this could be? I tried swapping the fuel pump and horn relays and that didn't help. Thanks.
Old Nov 12, 2008 | 05:59 PM
hotwheels57's Avatar
hotwheels57
Fuel pump going bad?
Old Nov 12, 2008 | 06:03 PM
lucky131969's Avatar
lucky131969
I would get a meter on the LH fuel level/pump assembly connector, and see if you have a good ground at pin D. Then you can verify if you have 12 volts at the connector (pin A) for that initial crank, or if the voltage remains at zero. Just turning the key to the on(run) position will turn the pump on for 2 seconds.
Old Nov 12, 2008 | 09:54 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I agree ,,your going to need to do some meter reading and ground cleaning. On a car thats as old as yours, its a very good idea to clean chassis grounds G-101, 102, 104, & 401. G-401 is the actual fuel system ground.
Something else that can cause this issue is the ignition switch.
Use a DC Volt meter and check the voltage at the "Under Hood Fuse Block, fuse #13, F/PMP 20 amp for voltage. LOOK ON TOP OF THE FUSE AND YOU WILL SEE TWO TEST POINTS. When you turn the key to ignition ON or START,,,there should be 12 DC battery voltage on both test points. If there ISN'T,,,,,the ignition switch could very well be causing the issue. When the fuel pump doesn't come on, do this test and see if there is or isnt voltage there during the fault.
If thats the case I have a post that explains how to clean and repair that switch for free.
Old Nov 13, 2008 | 09:21 AM
WardVette's Avatar
WardVette
Thanks for the responses. I'll check those after work today and report back
To Fuel pump does not come on during first crank
