Cam install Help (JPR Tool woes)
Old Nov 13, 2008 | 03:24 PM
11SECSS's Avatar
11SECSS
Default Cam install Help (JPR Tool woes)
Alright gentlemen... My crank pulley recently came loose so while tearing down the car I decided I might as well install a new cam since this is on the list for the future anyway... Ive got everything torn down and got the right side JPR tool slid in all the way with no problems at all.... The left side however only goes in only approx 2 inches... what gives? Ive spun the cam slowly about 100 rotations now and the JPR tool still wont go in any further... it even seems to get stuck a little when trying to pull it back out... Could I have a jammed lifter? Any help is much appreciated!
here's a pic of the tools in use on ls1howto... its the left side that is the issue...
Old Nov 13, 2008 | 03:53 PM
vettenuts's Avatar
vettenuts
This is typical of later motors unfortunately, get two 5/16" metal rods at Home Depot, round one end and then make them around the same length as the JPR tool or a bit longer and use them. The JPR tools had issues in later motors on the passenger side.
Old Nov 13, 2008 | 03:57 PM
11SECSS's Avatar
11SECSS
sounds good thanks for the input!
Old Nov 13, 2008 | 04:06 PM
OhioC5's Avatar
OhioC5
I gave my cam quick spins, not slow. Thats a great tool same one Ive used twice.
Old Nov 13, 2008 | 04:22 PM
11SECSS's Avatar
11SECSS
Yeah I spun it quick too... no dice...
Old Nov 13, 2008 | 05:02 PM
11SECSS's Avatar
11SECSS
You were correct! I just got back from Home Depot with the 5/16" rod.. rounded one end, and with a little massaging she went in! Thanks a bunch vettenuts!
Old Nov 13, 2008 | 05:03 PM
vettenuts's Avatar
vettenuts
Here is the rods I made and used on my 02 during the first cam change.
Old Nov 13, 2008 | 05:08 PM
11SECSS's Avatar
11SECSS
Looks exactly the same as mine!
Old Mar 19, 2015 | 03:31 AM
Mark Wade's Avatar
Mark Wade
Hi There why do they put those flats on them and they are facing a certain way the flats that is so surely they are required ? or not i will be happy if i dont have to machine those flats ,and yes i do have to make because im in new zealand where the tools arnt available ,thanks for the info looks lot easier than the magnet trick at 10 bucks each ,
Old Mar 19, 2015 | 06:51 PM
Paul 75 L82's Avatar
Paul 75 L82
Spin the cam fast. I was so scared when I installed my cam that I bought a telescoping pen magnet for every lifter. Really was cheap insurance to make sure a lifter didn't drop. So if you still have the problem just get some pen magnets and pull up the problem lifter.
Old Mar 20, 2015 | 01:03 AM
StingrayRebel's Avatar
StingrayRebel
if I remember correctly only one of them needs to have a small flat area on it, just grind a bit of it flat on a bench grinder it doesn't have to be perfect... I made my own as well out of a piece of steel rod that I cut down to size... if you spin the cam over a few times it should seat the lifters in the trays and hold them there long enough to pull the cam out and install the new one... none of mine fell out and made contact with the rods but it's better to be safe than sorry
Old Mar 20, 2015 | 01:27 AM
Mark Wade's Avatar
Mark Wade
we have done the job waited for engine to be dead cold then we actually pulled the lifters up further with a magnet our plastic trays were new from the week before so that was a great relief , so we rolled the dice i held the air con rad up while my worker pulled the cam and dropped new one in , if your puzzled why we were changing cam after a week on new engine, was we fitted dod cam in a non dod engine it just dosnt work dont listen to people who say it works we found out the hard way , thanks for input
To Cam install Help (JPR Tool woes)
