LS2 Timing Chain Dampener on LS1 Block?
Old Nov 14, 2008 | 01:57 AM
rikhek's Avatar
rikhek
Default LS2 Timing Chain Dampener on LS1 Block?
The link below says you can use the LS2 dampener on a LS1 provided your LS1 block is NOT already drilled for the LS1 dampener. I imagine you just drill the LS1 block to accomodate the narrower bolt centers of the LS2 dampener. Only question would be were exatly to drill......
https://www.crateenginedepot.com/LS2...P2276C119.aspx
Your thoughts would be appreciaed.
BTW, my block is NOT drilled/tapped.
Rick
Old Nov 14, 2008 | 06:42 PM
Russ K's Avatar
Russ K
I drilled/tapped the block & installed the GMP damper on my 2001 ZO6. The raised bosses on the block are spaced too far apart to use the LS2 damper.
Russ Kemp
Old Nov 14, 2008 | 09:56 PM
rikhek's Avatar
rikhek
Russ Kemp
Well that just sucks..... I thought I had a solution for installing a dampener.
Rick
Old Nov 15, 2008 | 07:51 AM
vettenuts's Avatar
vettenuts
Rick,
Did the drawing help? I think a piece of bulk nylon could be used to do this with some metal inserts.
Old Nov 15, 2008 | 08:59 AM
vsocks1's Avatar
vsocks1
Originally Posted by vettenuts
Rick,
Is this really needed if you use a high quality timing chain set like the Cloyes Hex adjust 3153AL?
Old Nov 15, 2008 | 10:05 AM
vettenuts's Avatar
vettenuts
Depends. Normal street driving probably no. What is does is prevent chain whip at certain RPM where there are known issues. If you run on the track then it may be a good thing to have (track being HPDE rather than drag racing where you pass through the RPM range quickly). This is at least my understanding of the issue.
Another thing to be careful of is to make sure the two sprockets are aligned during installation. This should be checked with the chain off, then install the chain.
Old Nov 15, 2008 | 12:49 PM
rikhek's Avatar
rikhek
Rick,
Making one from the drawing is at the top of my list. If I could just use the $15 LS2 dampener that would be a no brainer.
Might even be easier to buy a black LS2 dampener as a "mold" and drill it to the ~2.1" LS1 bolt centers.
Rick
To LS2 Timing Chain Dampener on LS1 Block?
