TCS 1226 fix
Old Nov 18, 2008 | 09:42 PM
T.J.'s Avatar
T.J.
Default TCS 1226 fix
I bought a new speed sensor harness, but it only has the one connector on the end. The sensor has two wires (yellow & blue) and do they just get wired in or is there a separate connector that needs to be purchased. The orginial stock part has plugs on both ends, but this new part does not.
Old Nov 18, 2008 | 10:17 PM
lucky131969's Avatar
lucky131969
yep, you need the other connector.
Old Nov 18, 2008 | 10:58 PM
byronhunter's Avatar
byronhunter
The vehicle speed sensor, and wheel speed sensors, are different. What you bought looks like it is for VSS. WSS cable has a connector on each end.
Old Nov 18, 2008 | 11:29 PM
T.J.'s Avatar
T.J.
Do you know of the part number for the WSS? I went to the dealer today and looked up the part on their comp and this is what it showed and the correct part number.
Old Nov 18, 2008 | 11:55 PM
byronhunter
Default Pt #
Try #12163714, You confirm before you order, ok?
Old Nov 19, 2008 | 12:18 AM
T.J.'s Avatar
T.J.
I looked at a diagram and it appeared to be the correct part.
Hold on I did find this.
Part number 12163714 was superseded by part number 10332527 (gmpartshouse)
Old Nov 20, 2008 | 10:02 PM
T.J.'s Avatar
T.J.
Back to the top
Old Nov 21, 2008 | 11:57 AM
voda1's Avatar
voda1
Usually a repair harness comes with heat shrink butt connectors and gets wired in.
Old Nov 21, 2008 | 10:25 PM
T.J.'s Avatar
T.J.
The package did have this
To TCS 1226 fix
