Weight reduction:
Old Nov 20, 2008 | 11:11 PM
SILVER ZO6's Avatar
SILVER ZO6
Default Weight reduction:
Is it necessary to take passenger seat out and drain out the washerfliud.
To gain more ''SPEED and SEC'' at the tack.Your only taken out about 35punds is it worth it.
Old Nov 20, 2008 | 11:14 PM
Oldvetter's Avatar
Oldvetter
Which tack is that ?
I'd take out the steering wheel and pedals too while I was at it.
Old Nov 20, 2008 | 11:30 PM
nickolbag's Avatar
nickolbag
its not necessary....but you will go faster without them.
Old Nov 20, 2008 | 11:31 PM
SILVER ZO6's Avatar
SILVER ZO6
Man your a real smart one. Yep you got a slow vette.
Old Nov 20, 2008 | 11:32 PM
SILVER ZO6's Avatar
SILVER ZO6
Is it
Old Nov 20, 2008 | 11:36 PM
nickolbag's Avatar
nickolbag
Originally Posted by SILVER ZO6
Is it
I do it when I drag race. Every pound is worth it.
Old Nov 20, 2008 | 11:43 PM
SILVER ZO6's Avatar
SILVER ZO6
I no u. Did you get my reply i sent you. I was to atco last year with the track rental cartek. I had the silver z06 that Dave was driving with the paint job on the hood.
Old Nov 20, 2008 | 11:48 PM
nickolbag's Avatar
nickolbag
Yup, got the reply. Are you heading back to Atco? Going to the next Cartek rental?
Old Nov 21, 2008 | 12:05 AM
happa's Avatar
happa
I weighed my 99 Coupe a few months ago and it weighed in at 3145 lbs. We couldnt believe it, so we did it over and over. I once took the seat out and ran my fastest time 7.3 @ 98 in a 1/8th. Whether that made a differance I dont know, but every bit of less weight will help out
Old Nov 21, 2008 | 07:28 AM
MagRedConv's Avatar
MagRedConv
Check your other post in C5 Gen. You might want to check out the Weights, Measurements, Ratios sticky in Gen as well.
Old Nov 21, 2008 | 08:03 AM
AU N EGL's Avatar
AU N EGL
Every pound is worth it. Take out 100 lbs out of the car could be about a 10 hp gain
Take 1 pound off the wheels, and that is almost like removing 6 1/2 lbs out of the car.
1 lb or rotating wt removed ~ 6 1/2 lbs static wt.
Good luck
Old Nov 21, 2008 | 02:11 PM
David426's Avatar
David426
South Beach Diet.. Lost 32 pounds
Old Nov 21, 2008 | 03:58 PM
SILVER ZO6's Avatar
SILVER ZO6
When is the next track rental
Old Nov 21, 2008 | 05:54 PM
nickolbag's Avatar
nickolbag
Not to sure. I have to call Julian and see exactly when it is.
To Weight reduction:
