autometer NEXUS boost gage problem.
Old Nov 21, 2008 | 10:47 AM
Smoove
Guest
Posts: n/a
Default autometer NEXUS boost gage problem.
I'm running the NEXUS gages, and i'm having a problem. I had a problem a while back with a module and atometer took care of my issue no problem.
Now, I have a seperate issue. My gages all do the proper sweep, when you turn them on or off. They all come on, including the boost gage but, my boost gage stays at pretty much ZERO vacum. Just sits there. Sometimes it stays at like 2-4psi. Just started doing this. Again, the gage does it's sweep on and off but, doesn't move with engine input.
I was thinking the MAP sensor might be the issue but, wasn't sure. I know it's a GM MAP but, not sure out of which year.
Could it be the gage?
Anyone have this issue?
Old Nov 24, 2008 | 03:23 PM
Smoove
Guest
Posts: n/a
bump...
Old Nov 24, 2008 | 03:38 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I would check all the connections to any component for the boost/vac gauge, being electrical and mechanical inputs. Make sure that there's no kinks in the plastick line for the MAP sensor, as that will make things funky in a heartbeat.
Old Nov 28, 2008 | 07:31 AM
Smoove
Guest
Posts: n/a
Thanks for the input man. Checked all those things the moment I noticed it,...so it's i'm leaning towards an internal component. Again though, thanks the idea's.
-J
Old Nov 28, 2008 | 10:54 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
How's the connection to the module and the connection to the gauge itself? Actually take the connectors off and see if the pins are still seated all the way. When I was playing with mine one of the pins actually started pulling out of the housing and caused some wackiness to happen.
Old Nov 29, 2008 | 09:45 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I installed those in Fastbirds car, they are made in China garbage, call AM, they often replace as they are known to fail
I think every connector fell apart on Fbirds install, terrible quality
Old Dec 1, 2008 | 07:20 AM
Smoove
Guest
Posts: n/a
Well that sucks. Pulling out? Makes sense that, that was the issue. Possibly due to the vibration/shock of the car, which, my car makes all kinds of vibrations(bumps/idle/etc). Thanks for the tip.
Wow every connector. I'll check the car in a few. Thanks for the tip hommie. You going to PRI this year?
To autometer NEXUS boost gage problem.
