Weird eletrical issue
Old Nov 22, 2008 | 05:39 PM
MJD's Avatar
MJD
Default Weird eletrical issue
Just finished with a brake and shock install when I had a weird eletrical problem come up. Out of nowhere a loud buzzing started and wouldn't stop until I removed the battery cable. I reconnected later and when I tried to put up the passenger side window it would not go and the buzzing started again but stopped this time when I turned the key off. I sounds like it's comming from the passenger footwell. Anyone have something like this happen? Is it possibly just a loose connection? What could possibly cause the loud buzzing sound?
Old Nov 22, 2008 | 05:58 PM
MJD's Avatar
MJD
I just tried locking the doors from the passenger side and it would cause the buzzing sound. It appears to be coming from the silver box behind the kick panel. Can any one tell me what it does and which connection is for the passenger side door?
Old Nov 22, 2008 | 06:25 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
The buzzing sounds like a relay oscillating. The relays for the window are in the door, so I'm not sure what's in the kick panel that's buzzing. Probably caused by low voltage from a bad connection or a resistive ground.
Old Nov 23, 2008 | 01:00 PM
MJD's Avatar
MJD
The car won't turn over, just gives a popping sound so I pulled the battery and will have it checked (I haven't ran it in about 3 weeks but I plugged in the tender to charge it). You mentioned low voltage, maybe my 6 yr old battery is finally giving out. Thanks for the help.
Old Nov 23, 2008 | 01:33 PM
hotwheels57's Avatar
hotwheels57
Failing/failed batteries cause a lot of annoying gremlins...
Old Nov 23, 2008 | 02:20 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
I got the same buzzing issue one day when adjusting the shift linkage and playing around in general.
Disconnect the battery and charge it back up completely.
You'll have to clear codes after you reconnect everything since it will have thrown quite a few.
Old Nov 25, 2008 | 08:52 PM
MJD's Avatar
MJD
Turns out it was the battery. Test showed it wouldn't hold a charge. Ended up getting a Diehard Platinum for a replacement. Thanks for the help fellas.
To Weird eletrical issue
