Something Wrong With My Motor???
Old Jan 15, 2002 | 09:14 AM
Rx7Rob's Avatar
Rx7Rob
Default Something Wrong With My Motor???
Anyone have a guess about this?
For the past few months my car has been feeling weak. It used to really bark the tires on the shift into 2nd gear (MN6), now it doesn't slip in the least. It also feels like the power really falls flat in the upper RPM's where it used to climb right to redline.
I pulled the plugs last month and found 4 of the 8 were missing the pucks. I replaced them with NGK TR's gapped at the factory setting. I hoped this was the problem, but it didn't improve.
I checked compression while the plugs were out and it looked ok. Gas mileage doesn't seem to have changed.
What do you think? Would a bent push rod have that effect?
Hey Steve; Wanna do some more Autotap runs one of these days?
Thanks!
Oh ya, its got about 8000 miles.
[Modified by Rx7Rob, 8:15 AM 1/15/2002]
Old Jan 15, 2002 | 10:53 AM
Paradigm's Avatar
Paradigm
Default Re: Something Wrong With My Motor??? (Rx7Rob)
Go the easy route and have a tech plug in to the PCM and get a picture of what's going on. Could be as simple as dirty wires on the maf or an O2 sensor.
Old Jan 15, 2002 | 12:06 PM
VettTheRipper's Avatar
VettTheRipper
Default Re: Something Wrong With My Motor??? ('98 Six Speed)
agree with 98, pull the maf and clean it with alcohol being careful of the delicate wires, would be an easy fix
Old Jan 15, 2002 | 02:24 PM
Rx7Rob's Avatar
Rx7Rob
Default Re: Something Wrong With My Motor??? (VettTheRipper)
Thanks guys! I'll see if one of the techs will check it out at our next club shop night. Then I'll clean the MAF (Q-tip and rubbing alcohol).
Old Jan 15, 2002 | 06:47 PM
Steve Row's Avatar
Steve Row
Cruise-In II Veteran
Cruise-In III Veteran
Rob, what's the Deal? Are you driving it too easy?
Vic has my cable right now but he is bringing back at shop night. You are welcome to it then.
If you need my son's lap top, we can get together like last time and run it a few times.
Your exhaust pipes are banging around causing Knock Retard, are they?
:confused: :confused:
To Something Wrong With My Motor???
