MSD Window switch- one cylinder operation?
Old Jan 15, 2002 | 09:48 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default MSD Window switch- one cylinder operation?
I just installed NX 150 Wet kit on my car (pictures are coming), I bought the MSD window switch but was told that I had to send it back due to the c5's one cylinder operation. Is anyone else using this product? Can you please comment...
Thanks..
Old Jan 15, 2002 | 02:58 PM
jetskifast's Avatar
jetskifast
Default Re: MSD Window switch- one cylinder operation? (ICULUKN-C5)
MSD window switch will work fine on C5. Setup as four cylinder as in instructions. Cut Red and Blue wires and you will be all set.
Also make sure you use MSD window switch as ground, for low load device like fuel pressure safety switch.
[Modified by jetskifast, 11:01 AM 1/15/2002]
Old Jan 15, 2002 | 07:41 PM
ICULUKN-C5's Avatar
ICULUKN-C5
I know that you can do that on the mallory window switch, but when I called MSD they told me to send it to them from recalibration. Are you using the MSD window switch?
Old Jan 15, 2002 | 09:18 PM
jetskifast's Avatar
jetskifast
Installed my nitrous with MSD window switch over a year ago, without any problems.
Many people on this board and http://www.ls1.com have MSD window switchs installed on there N20 LS1 motors.
To MSD Window switch- one cylinder operation?
