Thanks guys, can't believe I did this. I had a small chirp from the serpentine belt. So I sprayed a little WD-40 on it. Chirp went away, well why not spray a lot more on so it doesn't come back right. Now when I hit the gas the belt squeals like a stuck pig. How do I remove all the extra WD-40?
Happy Thanksgiving all.
You can use simple green or soap and water. I would remove the belt, and clean it thoroughly, and wipe down the pulleys(provided the belt is in good condition). Never use lubricants to silence a belt. A small amount is ok to use to isolate the noise, but it doesn't make sense spray lube on a surface that requires tension/friction to function. Finally, inspect the belt for wear and cracks.....it probably needs replaced.
GM even recommends that you not use a belt dressing on serpentine belts. It deteriorates the belt, and can also make the noise worse as the WD-40 did.
IF you are trying to isolate the noise, put water in a pump type sprayer, and mist a little on each belt. If the belt is the problem the water will quiet it the same as spraying the WD40 did and you do not have to worry about damage to the belt.
