H,C,&I questions
Old Nov 28, 2008 | 02:26 PM
zeevette's Avatar
zeevette
I think the AFR heads are a great idea if you plan on a SC. Much more robust construction than factory heads, and if you're gonna do pistons, the chamber size is not important. I'm also a proponent of higher compression, and if you don't get greedy on boost, it'll be more responsive, and efficient on the street with around 10:1. Don't know about FI cams, but whatever size you go with, a higher LSA-around 116-118 is supposed to be better.
Old Nov 30, 2008 | 11:25 PM
69dodgecharger's Avatar
69dodgecharger
bump
