lowering bolt and spring mod ?
Old Nov 27, 2008 | 07:34 PM
Konstantin's Avatar
Konstantin
Default lowering bolt and spring mod ?
has anyone tried grinding the spring where the bolt base is ? if u grind the spring flush ( that round raised area ) to the rest of the spring, and then enlarge the hole where to bolt goes in ( lose couple of threads maybe ), then the lowering bolt will go right in ( flush with the surface of the spring) and with bushings cut it will be same height as a car with stock spring and bolts removed altogether but still have an option of raising the car. any thoughts ?
- Kons
