Rocker implosion
Old Nov 29, 2008 | 04:18 AM
BOUT X's Avatar
BOUT X
Corvette Cowboy
Default Rocker implosion
Hello fellow vetters I had the #6 rocker on the drivers side break I have 2004 Z06 Rockers on my 2000 LS1 I lost all the needle bearings and pieces of the bearing area. I have found 6 needle bearings and several pieces of the internals of the rocker. My plan is to flush the motor with 24 qts. the last 6 will be with the motor turned over a couple times to loosen any pieces that remain then put in 6 qts of Mobil 1 run for about 20 miles and do another oil change. My concern is the pick-up filter in the oil pan should I remove and replace it. This is my first vette I have the car about 2 ft in the air with the front of the car at bout 1-1/2 ft up will I be able to remove the oil pan with car at the height. I know that thier is 2 pieces to the pan but the dealer didn't have the gasket for the bottom pan. PLEASE HELP WITH THE RIGHT WAY TO DO THIS if you have anything that you can e-mail me here is my e-mail dacemfg@sbcglobal.net
Old Nov 29, 2008 | 07:38 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
In order to remove the oil pan you have to drop the front suspension cross-member.
Old Nov 29, 2008 | 09:11 AM
gpracer1's Avatar
gpracer1
Get a magnetic drain plug, then drive around, then drain.
Old Nov 29, 2008 | 09:29 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
1. mid year C5's have a 2 pc. pan., you pulling the xmember for the bottom part?
2. mag plug, yes
Old Nov 29, 2008 | 12:44 PM
ZZOOM06's Avatar
ZZOOM06
If you drop the front crossmember you can remove the bottom part of the pan which will give you access to the oil pickup screen. The gasket is re-usable. HTH
Jimbo
Old Nov 29, 2008 | 01:36 PM
BOUT X's Avatar
BOUT X
Corvette Cowboy
I didnt know you need to drop the crossmember I cant do that
Do you know where to get on fast I went to 2 dealers and no one has it
Thats what I thought The dealer has the main pan gasket I dont have the tools or the lift to do the cross member.
2. mag plug, yes
Would love to find one
Jimbo
I was hoping I would have to drop the cross member it looks like I can drop just the bottom piece with no problem If I knew forsure that the gasket was re-useable I would do that
Any more help would be great and you guys thanks for your idea's
Old Nov 29, 2008 | 06:58 PM
Fasthotrod's Avatar
Fasthotrod
I got one at O'Rilleys. Cost about $6 I think.
The guy looked it up on the computer, then grabbed one off the shelf. Good luck.
Mark
Old Nov 29, 2008 | 08:54 PM
BOUT X's Avatar
BOUT X
Corvette Cowboy
Mark
I will check some of the auto stores a buddy came out and we found all 60 needle bearings and all the pieces that we could and after pieceing it back looks like we got it all. So now time for a little drive see how she does.
Thanks for all your help.
Dale
Old Nov 30, 2008 | 01:48 AM
BOUT X's Avatar
BOUT X
Corvette Cowboy
Well it works great got it all done took it for a 10 mile drive works great.
Old Nov 30, 2008 | 06:16 PM
countslav's Avatar
countslav
Good job Bro......
To Rocker implosion
