LS6 hollow valves.
Old Nov 30, 2008 | 11:37 AM
396375's Avatar
396375
St. Jude Donor '08-'09
Default LS6 hollow valves.
Did all 243 heads have hollow sodium filled valves?Is there anyway to recognize these valves while they are still in the head?I know in 2002 the valve was actually longer then a LS1 valve.Not sure about other years.
Thanks.
Old Nov 30, 2008 | 11:47 AM
The Wrench's Avatar
The Wrench
I am pretty sure the first year Z06 heads ('01) did not have the hollow/longer valves, due to less cam lift. But, I do not know if these were the same 243 head number as the '02-'04. All the '02-'04 had the longer/hollow valves with stronger springs also.
DG
Old Nov 30, 2008 | 11:58 AM
Konstantin's Avatar
Konstantin
do i need different pushrods if i use 02+ valves in 01 engine ?
Old Nov 30, 2008 | 01:58 PM
sami85L98's Avatar
sami85L98
I need to confirm this as well, as i was thinking all 01-04 Z06 have hollow sodium filled valves, now iam what 01 Z valves are?
Old Nov 30, 2008 | 02:22 PM
Konstantin's Avatar
Konstantin
01 valves are not hollow/sodium filled, only 02-04
Old Nov 30, 2008 | 02:34 PM
ctsv510's Avatar
ctsv510
'01 LS6 has the same valves as LS1. The only valvetrain upgrades in the '01 LS6 were the springs.
Here's a couple good links on the changes from the LS1 to the LS6:
'01 LS6
'02+ LS6
To LS6 hollow valves.
