Help w/ebcm problem
Now as soon as i started going forward the lights come on the dash and after checking codes it now has code c1233h.
My question is do i need a scanner to cleard history code or is there any other way? Are there any aftermarket scanners that could clear a chassis/body code?
Any help would be greatly appreciated!!!
When you previously checked the sensor did you hook up a DVM to the sensor outputs and spin the wheel bearing to see if you got an AC signal of the proper level?
Bill
Bill
Bill I did test sensor with a meter. I also tested the left sensor for comparison and they were equeal. Do you have a range for the ac volt levels. And will spinning it by hand be enough.
Is it likely in your experience that a hub could go bad on a 10k mile car that sees not rain?
Thanks again guys!
Thanks again guys!
Measure the resistance first and if it is within spec then measure the voltage. If either is out of tolerance the wheel bearing has to be replaced.
As for the miles it isn't likely the bearing is bad but it is possible.
Bill
RECOMMENDATION:
Go to NAPA, Advance or Autozone and see if they sell the replacement MALE pin for tht connector. Purchase a couple of them. I will attach pics of the single male pin later
BC
FYI---The light comes on instantly after clearing at about 7 mph.
Heres the male pin that I use to test mine:
If the EBTCM fails at 7 MPH every time,, thats a problem with the microprocessor inside the EBTCM and theres NO way anyone will be able to fix that issue short of obtaining a complete new EBTCM. My 02 Z EBTCM failed repeatably at 42 mph. I just repaired one that failed at 11 mph.
As long as you stay under that MPH threshold, it will work fine. Right???
BC
Bill, Yes the lights always come on at same speed. I had my ebcm repaired by AUTOECU, and they said they found problems but all were fixed. You said you just repaired one that was coming on at 11mph. Do you mean you repaired existing unit or did you replace it? I really don't want to drop a grand if I don't have to, but it might be going that way.
No way! Get one from Gene Culley for a LOT LOT less and install it your self!Yea the ABS Fixer companies make plenty of cash on repairing the modules BUT,,,I do NOT believe that they can fully test them. The problem that your having has NEW MODULE written all over it. Thats how I repaired my friends car. I have a spare EBTCM that we bolted in. Fixed it right up.
In fact the module that he replaced the original suspected bad OEM module with was a module from ABS Fixer. The ABS Fixer Module turned out to be the wrong series module and it had the 11 MPH error issue. We changed his module out with my spare for testing in 15 mins. He called Brandon and worked something out. He got another module to replace the ABS Fixer module. I suggest that you do the same. They warranty that stuff or at least that what they promote. If they don't honor it, we need to know so we can do business with the most repeatable companies.
EBTCM Module and BPMV together:
EBTCM separated from the BPMV:
EBTCM
Its a plug and play module.
Bill
