Replacing shift indicator bulb
Old Nov 30, 2008 | 05:28 PM
bobc997615's Avatar
bobc997615
Default Replacing shift indicator bulb
The manual says:
"Grasp the cable end and pull rearward in order to unlock the cable from the shifter pivot arm stud, then reposition the cable."
Does the shifter cable clip just "snap" over the stud? So I actually pull the cable & clip rearward to remove from the shifter stud?
I don't want to pull hard enough to break something or to be doing it wrong from the start.
Thanks guys.
