oil sending unit bad...
Old Jan 15, 2002 | 08:35 PM
rayjerman's Avatar
rayjerman
Default oil sending unit bad...
my '98 has lost oil pressure by about 10psi. it is running just as good with no noises still. i spoke to a gm tech. at the dealership and he said it sounded like a faulty oil sending unit or oil psi gauge. it did the same thing about 3 weeks ago and i changed the oil and filter and psi went up to normal, but dropped back down 2 days ago. has anyone had this problem or know what it might be.
Old Jan 15, 2002 | 09:15 PM
Ray'98's Avatar
Ray'98
Default Re: oil sending unit bad... (rayjerman)
Just had mine replaced, '98 also. Oil pressure read >80psi at idle (checked with gauge). Pain to change had to remove the intake manifold. A common failure too bad they don't have a real fix other than replacing one bad sender with another iffy one. It might be a good idea to relocate the sending unit, using a extension hose etc., to an easier place to get at. At least it would be easier next time.
Old Jan 15, 2002 | 09:16 PM
MDT's Avatar
MDT
rayjerman,
I think your tech got it right.
Good luck.
Mark
To oil sending unit bad...
