brain trust question on abs
Old Dec 1, 2008 | 01:07 PM
tonycorvettes's Avatar
tonycorvettes
Default brain trust question on abs
ok im getting a C1242 c h BPMV Pump Motor Ground Circuit Open and i have sent my abs mod off for testing by abs fixer,its supposed to be good,,,knowing all this and i understand somewhat how the system works,,,if im wrong please tell me,,but i think when the key is turned it sends voltage to the unit ,,1st question,,can i open the plug and use a test light or volm meter to see if that battery is there? 2nd ouestion i think there is supposed to be a ground potential looking into the femaile plug ,is this true?but whta contacs and anyone have a picture of how to count them?thanks...also would it be safe to say tha 99% of the time this trouble is probably a bad connection or bad ground?
Old Dec 1, 2008 | 01:16 PM
lucky131969's Avatar
lucky131969
Ok, I'm assuming you have a C5 by the code you posted, but your sig says you have a C6. Helps to know what year car you have....
Old Dec 1, 2008 | 01:44 PM
Bill Dearborn's Avatar
Bill Dearborn
You have multiple threads opened on this subject. It would help if you consolidated all of this.
Bill
Old Dec 1, 2008 | 04:43 PM
tonycorvettes
Default because
i thought if i open a new thread i would get a responce and poeple dont look at old ones,,i dont know,,,sorry,,,anyway i have found something maybe you know about it,,i checked the ground on the left fender front ,its good ,,but there are 4 black wires together in the plastic housing and one black by it selt with an eyelet ..with an olm meter reading from that eyelet end to the housing of the abs unit i get 13000 olms,,should i have a almost solid reading there ?what is that wire,,thanks and yes its a 2001 thats the picture,i sold my c6 didnt like it ,just disnt feel like a corvette to me
Old Dec 1, 2008 | 11:44 PM
tonycorvettes
no takers?
Old Dec 2, 2008 | 01:31 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
i would assume you should have very low resistance as that metal should be grounded. IMO u lost a ground somwehere
To brain trust question on abs
