What the eff was that!?!?
It does not happen if I let the clutch out really slow and take it really easy getting started. It does not happen if I smash the gas, though I spin tires in 1st and 2nd. And it does not happen if I slam through gears while drag racing. It only happens when engaging the clutch from a stand still under normal or more load. The clutch holds power (H/C car) and does not seem to slip. I have no strange feelings in the clutch or anything, so this leads me to believe it is not the clutch. I have removed the bellhousing inspection cover and all seems well in there. I have removed and retorqued my exhaust manifolds and the h-pipe. (It really sounds like the exhaust is binding right under the center console). I have even removed the 2 bolts connecting the front of the h-pipe to the bellhousing to see if the noise changed, but I didn't notice a difference.
I really dont want to have to tear the car apart AGAIN. (The car has seen more time in pieces than together in the past couple months) I am hoping that someone says, "HEY! I had that exact same problem and this is what it was!" Wouldn't that be nice... Any ideas folks?
I really wish I could post a video but I don't own a video camera and I don't know how to get video from my phone to this forum. I know it is hard to imagine a sound that someone tells you about. My girlfriend says it sounds like a car horn
But I think it sounds like air brakes on a semi.
But I think it sounds like air brakes on a semi.hey look at it this way, u enjoy doin the work at least right? its a learning experience for me and i would rather do the work myself even if i could get it done for free
I've never been able to get that technique to work, it's just
frustrating as, well, you get the picture.To the OP: Can't tell without hearing the sound, but the conditions under which you hear the noise is very similar to my '94 Z-28 when the clutch started chattering. Just a very loud, horrific, vibration-inducing noise. Treat it gingerly, no problem. Let it out aggressively, little or no problem. Clutch never slipped under full throttle load, say in 3rd gear (tires would slip in lower gears).
The only way I fixed the problem was to replace the clutch/PP and have the flywheel resurfaced.
Frankly, I hope I'm wrong, it would be a real bummer to replace that many parts and have them die within 500 miles. Could it be a break-in procedural error (don't know, since I'm not familiar with those specific parts).
HTH, and have a good one,
Mike
Well, looks like I will have to take it all apart...... dsipos05, yes I do enjoy doing my own work, but I just did clutch, then heads and cam a week later, then had to take it all back apart to replace my crank pulley bolt a few days after the H/C. In the past 2 months I think my car has been off the road more than on and it's my DD. I don't get much time out of my day to work on it, so a one day job turn into a one week job.... UGH
sorry for the rant....
man i totally understand ur frustration, my vette's my dd too and ive been driving my wife's ford... oh no!!!!!!!!!!! i cant believe i said it... hopefully my treason wont last long
Mike
And no, I have no oil leaks from the bellhousing. I don't think I damaged the plug as I didn't really have much room to swing a hammer to compress the grease anyway. The pilot bearing puller I was using broke 4 or 5 times while trying to remove the bearing. I kept welding it back together but finally just gave up and put the car back together.....
