Maybe it's just late... Anyone have/install Part # 12649 or Part # 14778?? The ones with no mufflers, not sure where the mounting tabs go.. Looking for pictures or insight here..
Here is the set i'm installing:
the two tabs on the outside- where do those mount? I see nothing to bolt these things to!
Once again im steping in to provide the REAL answer here, not opinionated jargon.
To the OP those brackets mount are sandwidged between the rear sway bar and the cradle.
To install, simply remove the sway bar top bolts on each side, and place the bracket between the sway bar and the frame and reinstall the bolt.
And your done
Good gracious.. if you were in the neighborhood I'd buy you a beer or 6. I'd have never come up with that. I'm going to go downstairs and try it right now.
Thank goodness for the forums.
I just dug up a picture for you to make sure you have it right. THis was from when i pulled the driveline out to rebuild the trans.
Look above the sway, youll see the bracket and the rubber mount bolted to it, the exhaust slips on that top stud.
looks like both the brackets are missing,... Youll need to call borla to order them, If u got these new they should owe them to you free
Got'em 2nd hand... guy i bought them from is checking to see if he's got them still, otherwise I"ll call borla. Thanks for posting up, I would have pulled my hair out wondering WTF was going on.
awesome, just have to call borla and either order some brackets or make some myself. I see you thought your ssagged a bit, I was looking at mine thinking they'd be a bit low as well.
called Borla- they "don't normally piece meal stuff like that" but they're going to see if they can figure something out and call me back.. that'd be good since the rest of the exhuast shows up today...
