Serpentine Belt Chirp
Old Dec 2, 2008 | 08:46 AM
vetdude's Avatar
vetdude
Default Serpentine Belt Chirp
Car: '98 Corvette conv. A4
Mileage: 40k original
Problem: Belt chirp
Cure: replaced OEM belts with new OEM belts; still chirp
Cure: replaced tensioner pulley and idler pulley; still chirp
Problem diagnosis by my Forum brothers? GM belts? C5 pulleys? WTF??? Service appointment to get fixed [again] this Monday, 12/08.
Any input would be appreciated. Thanks in advance.
Old Dec 2, 2008 | 09:58 AM
fixvet's Avatar
fixvet
I got the "chirp" last summer at 62K miles on my '98 coupe. Put on a GatorBack belt from Kragen's that cured it. I only replaced the alternator/water pump accessory belt. Did you replace the a/c belt too? If you didn't, perhaps the chirp is only from that belt. It's harder to replace than the access. belt, but not bad!
Good luck.....
Old Dec 2, 2008 | 10:09 AM
vetdude's Avatar
vetdude
Good luck.....
Yep, replaced both belts with GM belts and both pulleys (a/c tensioner/idler) with GM units.
Old Dec 2, 2008 | 11:02 AM
Nver2loud's Avatar
Nver2loud
mine chirped after 2 different belts, i ended up putting on a new crank pulley, no more chirping Its quite amazing how much that little tiny bit of wobble affects things
Old Dec 2, 2008 | 11:33 AM
k0ts's Avatar
k0ts
Did you try cleaning all the pulleys?? Might be contamination on a pulley..
Old Dec 2, 2008 | 01:15 PM
j curtiss's Avatar
j curtiss
I, too, cured my belt chirp by replacing the crank pulley.
Old Dec 3, 2008 | 12:56 AM
PierEagle's Avatar
PierEagle
My '98 chirped. Thought it was the upper tensioner. Replaced the pulley, still chirped. Replaced both belts with Gatorbacks 6 months ago. No chirp since.
Old Dec 3, 2008 | 10:42 AM
Jims79's Avatar
Jims79
where can I buy gatorbacks from? also I heard if you buy a smaller belt by only a few mm it helps. anyone know if that's true.
Old Dec 3, 2008 | 11:37 AM
jovette's Avatar
jovette
Can purchase gatorbacks from Auto Zone. Don't have an answer to your questions regarding purchase and installation of smaller belts.
Old Dec 3, 2008 | 01:09 PM
warren s's Avatar
warren s
The chirp was the first indication that my balancer was coming loose and moving foward.
Old Dec 3, 2008 | 01:52 PM
PierEagle's Avatar
PierEagle
Got them at AutoZone.
For a '98, The A/C belt (42") is Goodyear #4040420 -$17, and the Alt/PS belt (80.25") is #4060802 -$33.
Also, for a "00, the Alt/PS belt (79.875") is #4060798 -$28.
I'll check this evening to see which Alt/PS belt I used and advise.
Old Dec 4, 2008 | 12:10 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
See this link
http://forums.corvetteforum.com/c5-g...e-ac-belt.html
My squeek was resolved with replacing number 9, 10, and 2 for really bad wobble. Crank balancer pulley separation.
Old Dec 4, 2008 | 06:16 AM
glass slipper's Avatar
glass slipper
I put a slightly smaller belt on my daughter's '99 Coupe and sister-in-law's '98 Conv 4 years ago and the chirp never came back. It's amazing what a difference a couple of mm makes.
Old Dec 5, 2008 | 12:30 AM
tirejoe's Avatar
tirejoe
6th Gear
gatorbacks worked for me,Jegs has them.
Old Dec 5, 2008 | 07:52 PM
RedC5's Avatar
RedC5
My '98 chirps when engine and outdoor temp are really hot, but goes away in park or neutral.
Old Dec 6, 2008 | 09:37 AM
jamminin98's Avatar
jamminin98
6th Gear
My 01 convertable chirps/ squeals, whatever until it warms up for 30 minutes. Going back to the shop today for the third time. it's driving me nuts!!! Turn up the radio....
To Serpentine Belt Chirp
