Which heads have biggest chambers?
Old Dec 2, 2008 | 06:46 PM
intoc6s's Avatar
intoc6s
Default Which heads have biggest chambers?
Does anyone have chambers bigger than 70 or 72? Thanks-Jason
Old Dec 2, 2008 | 07:45 PM
vettenuts's Avatar
vettenuts
I will throw this out there. Contact Tony Mamo from AFR. He does some chamber work that increases flow by un-shrouding the valves. This of course provide a larger chamber that is then corrected by milling. So if you don't mill you could end up with a great flowing head that has the larger chamber you are looking for.
Old Dec 2, 2008 | 10:31 PM
99 vett babycar's Avatar
99 vett babycar
To Which heads have biggest chambers?
