Traction light/abs light can you help?
Old Dec 4, 2008 | 08:19 PM
mario7669's Avatar
mario7669
Default Traction light/abs light can you help?
Ok i removed rack and pinion to install new harmonic balancer when replced everything back the traction light,and abs light came on when i took the car for spin so my question is what did i do wrong that those warning lights came on ?these where a few codes that came on when i did manual diagnostics
1571 pcm
1293 tcs
b2265 rdcm
2100 rfa
Old Dec 4, 2008 | 09:01 PM
lucky131969's Avatar
lucky131969
1571 pcm
1293 tcs
b2265 rdcm
2100 rfa
year please......
Old Dec 4, 2008 | 09:11 PM
lucky131969
ok, process of elimination....must be a 2000 or earlier. Based on the 1293 and P1571 code, you probably hosed something up on the EBTCM in the course of pulling the rack, unbolting the EBTCM, etc. Check the harness connectors, etc.
Old Dec 4, 2008 | 10:19 PM
mario7669's Avatar
mario7669
Old Dec 4, 2008 | 10:22 PM
mario7669's Avatar
mario7669
what do you mean hosed something up on the EBTCM?and what about unbolting the ebctm,dont understand. thanks
Old Dec 4, 2008 | 10:29 PM
lucky131969
yep, 97, so much for that code analysis. For future reference, it helps if you fill out your sig.
Old Dec 5, 2008 | 01:00 PM
jedblanks's Avatar
jedblanks
1571 pcm
1293 tcs
b2265 rdcm
2100 rfa
My 97 has a persistent 1571 that is not related to ABS/Trac light I think there is a TSB about this code in early models.
RDCM is right door control module, also not related
rfa is not related.
So it's the 1293 throwing the light. If it goes out when you shutdown/restart the car, it might not be a problem. At least that's what the manual says.
To Traction light/abs light can you help?
